Old 09-05-2008, 11:33 PM   #2056
asw7576's Avatar
Originally Posted by Bad Mika View Post
anyone knows of any good price 'slighltly smaller diameter' braje disks >
many thanks
Team Magic G4S brake disc.
Old 09-06-2008, 09:36 AM   #2057
gentleman81's Avatar
Originally Posted by lil-bump View Post
How can you tell the physical diffference between the to-138 and to138b front uprights? What lower a-arms must be used with each. I have a bunch of front uprights just not sure which one's they are???
Pass you soon...
im super late on this question, but along with the mounting location to the upright man body and the arm portion, if you look at the re-enforcing brace where the R and L are stamped on the uprights. the 138 has the R and L clearly stamped. the 138Bs, have the R and L cut off about half way.
i am out of the 164s so i cant say how to tell them apart
peace out homeys
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 09-06-2008, 10:28 AM   #2058
lil-bump's Avatar
Trader Rating: 83 (100%+)
peace out homeys
Better late than never. So your saying the 138B's have a partial "R" and "L" stamped on them and the 138 are clearly stamped. Is this correct??
Thanks for your input
Well, I just went and checked the parts; and you are correct. The original 138's have a full R and L stamped on them The uprights on the car have the letter's only partial stamped. So it seems that all of my spares are 138's and the one installed on the car are 138b's. I also checked the linkage mounting point of the two; and they are totally different between the two. Well needless to say I will probally toss all of my spares (5 sets of left and rights) I like the steering feel of the 138b's and I don't want to run into a situation of having mix-match uprights on opposite sides of the car. I also think I have the wrong lower arm installed on the front because when I go to full lock the steering linkage hits the lower arm.
Anyone looking for some to-138's for a steal shoot; me a pm otherwise they are headed to the round file.
Thanks a million gentlemen
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 09-06-2008, 01:09 PM   #2059
go to the mtx3 thread, they use the 138s
Old 09-08-2008, 03:02 PM   #2060
Trader Rating: 57 (100%+)
I have quite a few MTX4R parts for sale. Search MTX4 in the for sale section. Thanks.
insanewulf is offline   Reply With Quote
Old 09-09-2008, 09:50 PM   #2061
Default getn dialed in
My car seems to always inherit a push, if not immediately, after a few laps. Low speed acts like it is pretty close but I definitely canít carry too much speed into a corner, or it will push out easy.
Any help is good.
Good prepared surface
Front toe: 1.5 out (maybe the issue?)
Camber: 2
600 oil, stock piston
Center shock position
Front multi diff, locked
Stock steering ackerman
Caster clips, one large and one thin one front side, single thin on rear
2mm roll center shims
Sway bar parallel
Droop: 1
Rear toe: 3.5-4.5 in
Camber: 4 and coning well
Rear diff 50k I think, one step thicker than stock
Shock position: at the top or one from top right now
Rear roll center at bottom
2mm camber shims
Stock sway, softest setting
Droop: 3
Light blue springs front and back
Stock pulleys
Running 40/42s and 42/45s
Old 09-09-2008, 10:00 PM   #2062
Arahawak's Avatar
Trader Rating: 32 (100%+)
Any help is good.
I am not an expert but no harm trying these
Front toe: 1.5 out
Camber: 1
One way
steering ackerman A
Caster clips, stock
1mm roll center shims
Sway bar 45 deg
Droop: 1
Rear toe: 2.5 to 3 in
Rear diff 30k
Shock position: Stock
2mm camber shims
2.2 sway bar, if using adjustable 45 deg
Droop: 4
Stock pulleys
Change one thing at a time.
I always try not go too far away from the stock setting which works pretty well for most tracks. So that is what i will do.
Have fun.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-09-2008, 10:09 PM   #2063
thanks for the advice, and the laser surgery!!!
Old 09-10-2008, 08:43 AM   #2064
bsmooth's Avatar
Trader Rating: 17 (100%+)
What bodies do you guys like for this car?
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 09-10-2008, 10:31 AM   #2065
quietstorm76's Avatar
Any help is good.
I never liked running more than 2-2.5 deg of rear toe. The car always pushed for me.
I hated the bottom rear roll center position, it too pushed. Car just would not rotate mid corner or corner exit. Try middle or upper position. 3 droop is what I usually ran. Camber seems ok as well.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-10-2008, 10:41 AM   #2066
Thanks,
Steve
Protoform stratus 3.1 or the central east civic
Primary Weapon: ?
Secondary Weapon: ?
Old 09-10-2008, 12:41 PM   #2067
Francis M.'s Avatar
does anybody have an exploded diagram for the mtx4r
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 09-10-2008, 02:05 PM   #2068
Send a message via AIM to masa227 Send a message via Yahoo to masa227
http://www.mugenseiki.co.jp/mugen/do...nual_t0060.pdf
masa227 is offline   Reply With Quote
Old 09-10-2008, 05:40 PM   #2069
3mm droop rear
and what up front?
i think i have gotten so far from stock that i created my own issue. i added the extra toe to get it to rotate. i should have tried something else when i saw it getting to be too great.
Old 09-11-2008, 07:28 AM   #2070
3mm droop rear
and what up front?
0 or 1 on the droop up front. Biggest bang for the buck for me was raising the rear lower pins. Like I said try middle first.
Primary Weapon: ?
Secondary Weapon: ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
