Old 08-31-2008, 11:14 PM   #2026
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by lil-bump View Post
I placed them all side by side and part that attatches to the steering linkage are all at the same height. I'm pretty sure the to-164(2 degreee) will look totally different. I just need to see the difference between the 138 and 138b front uprights. thanks for the info any other info will be appreciated.
Pass you soon...
Let me try get some pics up tonight to show the difference.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-01-2008, 02:24 AM   #2027
Part no. Steering Kingpin
T0138 HIGH Vertical
T0138B LOW Vertical
T0164 LOW 2deg
I hope you can understand the table above...
The difference between T0138 and 138B is the steering mounting point, the original is 3mm higher. T0164 has upper pivot ball more towards the center of the chassis (kingpin 2 degrees inclined). The difference between T0138 and the rest is easily visible when you have them side-by-side. Between T0138B and T0164, IIRC the T0138B outer edge is flat, the T064 is a little inclined at the upper pivot ball.
You must use the newer lower arms with both T0138B and T0164, or cut the old arms to fit, it's not hard.
olev is offline   Reply With Quote
Old 09-01-2008, 03:16 AM   #2028
what are the difference between T0138B and T0164 on car handling?
Mugen MTX4-R
MM Red Dot Evo3
RB R3
Mugen MBX6
RB C6BBT
RB WS7II
sllo is offline   Reply With Quote
Old 09-01-2008, 04:18 PM   #2029
tony montana's Avatar
Trader Rating: 66 (100%+)
the 64's worked very well for me on a big track with alot off on power steering. I could be wrong but I think the 138'bs offer more steering. I think to run the 138's you have to change the front lower arm. Could be wrong thou.
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 09-02-2008, 12:46 AM   #2030
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by Arahawak View Post
Thanks dude. Its made by?
Penguin RC made those . i had them on my MTX2 & 3 as well.
They still sell them for a whopping $2.99
http://www.penguinrc.com/products/mu...iki/p6000.html
stefan is offline   Reply With Quote
Old 09-02-2008, 12:57 AM   #2031
stefan's Avatar
Originally Posted by quietstorm76 View Post
That was my finding in that the gear was heating up. My issue was that my end bell was touching the 2speed housing.
This is so strange. I am through my fourth MTX4 (R), my son through his second, and I have lots of friend with MTX4's and nobody i know ever had this gear stripping problem, ever.
I asked team drivers about it, and since they never had it, they can't offer any help.
Btw, I had my clutch bell touch the 2-speed housing in a 30 minute heat 2 weeks ago. Deep groove but not gear stripping.
What we have seen lately is a few XRay drivers with stripped spur gears
Old 09-02-2008, 01:09 AM   #2032
itchy b's Avatar
I didn't have a gear stripping problem with the car for the first year i had it, and the car was a used one!
Then i started having gear stripping issues, which i found were due ti a worn 2 speed shaft and i replaced the pinions with steel ones and fitted new spur holders which seemed to fix the issue.
My friend changed to the new 4mm ball 2 speed shoe set which seems to have fixed his stripping issues and also made the 2 speed shift better and also consistently.
I find that the old 2 speed can shift heigher and lower in the rev range with the same setting which can be frustrating, but i think that once i change mine to the 4mm ball set, it should solve the problem!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 09-02-2008, 01:41 AM   #2033
Arahawak's Avatar
I dun suppose they do international shipping do they?
Old 09-02-2008, 01:44 AM   #2034
Arahawak's Avatar
Well, all i can say you one of those lucky dude! I have frens who has not stripped any gears too and a few who has.
Its still a mystery.
Old 09-02-2008, 02:17 AM   #2035
NiTrO BoOsTeR's Avatar
gday, i am also one of the racers who have never striped a gear on my MTX4r i have done a whole season with out striping a gear, they are looking a little bit worn but i can still get a perfect mesh, i use the 3racing metal brace that goes from the rear bulkhead to the radio tray.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 09-02-2008, 02:46 AM   #2036
The new lower arm can be used with all steering blocks, the old arms can be used only with original T0138, for other blocks they have to be modified a bit.
Regarding difference between T0138B and T0164, I have always felt the T0164 to be more aggressive and give more steering everywhere. I have not gone back to T0138B after switching to T0164...
Old 09-03-2008, 01:36 AM   #2037
asw7576's Avatar
Just some toughts about braking and brake fading.
Beginning of this year I modded my car's braking linkages without use of silicone tubing. The braking movement thus was set up only through EPA ( end point adjustment ). I set the maximum braking point so I can brake effectively without locking, nor spin out at mid cornering.
I feel the braking effect is more solid and definite without existency of silicone tubing. I test this not just for 5 minutes ...., but for the whole race duration involving continuous braking at 2 spots. The braking is always consistent without fading or sagging effect.
I also shortened the brake rod to minimum length for a tidy look on my car.
Old 09-03-2008, 02:13 AM   #2038
Arahawak's Avatar
I have always tot that brake fading happens when the pads are over heated over a period of repeated usage which result in the loss of stopping power.
I am just curious how would your method help keep the pads in maximum working temperature.
Old 09-03-2008, 10:59 PM   #2039
asw7576's Avatar
So far I don't have overheated problem, or fading problem, the brake is always there. Maybe because my home track's layout only involve 2 spots of braking area, and 2 braking spots are not enough to overheat the brake disc. ( I always suspect the length of silicone tubing is the one which can lead us to feel the braking power is fading ).
Just another tips : Put a rubber band on the brake lever ( or a spring on the brake rod ), so when you full throttle, the brake lever is push backwards, making the brake disc 100% free wheeling.
I think these pads are not like in Formula 1 cars, .... you don't have to heat them up to working temperatures.
Old 09-04-2008, 01:21 AM   #2040
Arahawak's Avatar
Interesting. about the silicone tubing thing you mentioned.
No la, i dun think the pads needs to be heated up to working temperatures. We all know that the pads and the disc has to be 'clamped' in order for braking to happens. When the pads comes together with the disc, it creates friction, friction causes the 'braking' and friction creates heat.
The reduction of friction termed brake fade is caused when the temperature reaches the "kneepoint" on the temperature-friction curve.
I think i'm very lousy at explaining
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
