Old 08-21-2008, 10:32 AM   #1921
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by Ron C. View Post
Bobby,
Where do you have your Caster Settings?
Also, what steering ackerman do you have at the moment?
steering ackerman is "A" and not sure how to the caster
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 08-21-2008, 10:35 AM   #1922
JayL's Avatar
Originally Posted by bobbyblaze View Post
basically stock and the tweeks you made at the bowl... my first problem was it was spinning out on the turns you solved that...... now i think its pushing out...I'm running 37 shore front and rear at PT and parking lot track i use 40 shore
Try this easy change: add more front camber
JayL is offline   Reply With Quote
Old 08-21-2008, 11:56 AM   #1923
you change caster with the little plastic "C" clips on the top arm...you can move them around. More clips up front the more caster, more in the rear less caster and more upright....
Baedarlboo is offline   Reply With Quote
Old 08-21-2008, 12:17 PM   #1924
Ron C.'s Avatar
Bobby,
- Ackerman : You're okay, stick to the "A" since that gives most steering during Exit Corner.
- Caster : Try to play around with this. In simple terms, more clips sitting near the front of the car = more ON-Power Steering. And more clips sitting toward the rear of the car = more OFF-Power Steering.
JayL's suggestion of adding more front camber is a good next step as well.
If, after all the above is done and you need more steering, I would start playing around with Track Width and go narrow setting. I.e., the narrower it is the more bite you get. Remember to go a little at a time.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 08-21-2008, 03:16 PM   #1925
mo
mo's Avatar
bobbyblaze: What tire diameters are you running front and rear and what side pulley are you running. I would assume you are running the 24t as per the instructions so you could try the 25t pulley. That should give you more steering. I know it did for me. I usually start my tires off at 60mm front and 62mm rear.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-21-2008, 03:58 PM   #1926
Casey Belarde's Avatar
check your droop settings also
Casey Belarde is offline   Reply With Quote
Old 08-21-2008, 07:55 PM   #1927
Arahawak's Avatar
Trader Rating: 32 (100%+)
Usually, I try not to touch the caster settings. I much like to leave at neutral. I think it is a too "advance" setting to touch.
Like what Ron C. says, when - "Caster : Try to play around with this. In simple terms, more clips sitting near the front of the car = more ON-Power Steering. And more clips sitting toward the rear of the car = more OFF-Power Steering."
I will be confused when i do that.
Just a tip: If all else fails, revert to stock set up as per the instruction sheet and work from there again. The stock set up pretty much works in almost all tracks. That's the beauty about Mugens.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-21-2008, 08:54 PM   #1928
Originally Posted by stefan View Post
I'll clean my car tomorrow and take a pic.
still anticipating pics....
Old 08-21-2008, 09:46 PM   #1929
bobbyblaze's Avatar
BRAIN FART LOL thanks for the refresh should have know that
Old 08-22-2008, 09:49 PM   #1930
Spaza's Avatar
Does it smell?.............
MTX4-R - NOVAROSSI 353 TUNED - KO HELIOS.
B.R.C.C.C member
Spaza is offline   Reply With Quote
Old 08-23-2008, 09:29 PM   #1931
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Your car was looking good today!
I had so much fun with this car! Cant wait to race tomorrow! Going to be a good one
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-24-2008, 07:34 PM   #1932
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Well i stripped 4 gears today and lost 2nd place in the a-main I was lucky that when they stripped in the quals there was only seconds left. In the main, there was 7min in a 15min main...
Does anybody use this?
http://www.ybslowinc.com/products.php?item_id=14
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-24-2008, 07:55 PM   #1933
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Man I love the car, I just had a practice with this car this weekend for the first time and man it was AWESOME.
BLKNOTCH is offline   Reply With Quote
Old 08-24-2008, 08:11 PM   #1934
Arahawak's Avatar
I empathise with you. I hold the local stripping record and now i have resolve the issues. Some things i did which may help you.
Check the screws mounting the rear bulkhead if they are loose or stripped? If so change the rear bulkheads.
Make sure all screws on the engine mount is not loose.
Minimum play on the rear shaft.
I am also using the new 2-speed housing and newer spurs.
Try to use the original shims that came with the kit when you are doing the clutch bell end play. I found that by switching to the smaller shims (Tamiya or HPIs) i tend to strip my gears again.
Hope this helps.
Old 08-24-2008, 08:33 PM   #1935
Sounds like me!
LOL. I cant blame it on my car though, I had some nice hits. And I wasnt going for 2nd Maybe 3rd, But I think 4th it was...
Fun day, car is great, couldnt ask for more! Just more track time, and a new motor that HAS bottom end!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
