Old 08-19-2008, 07:15 AM   #1906
Bad Mika's Avatar
Default lipo regulator...
Originally Posted by Scott Fisher View Post
In the month of August alone, I have run a 60 min main and a 45 min main using a lipo and a Novak 3 amp regulator in my Kyosho sedan. Have run other 45 and 60 min mains. No problems yet.
hi, any idea if 6v 2amp regulator will work fine or the minimum is 3 amps... i've seen others with 6v 5amps type..
Bad Mika is offline   Reply With Quote
Old 08-19-2008, 10:44 AM   #1907
asw7576's Avatar
I would not risk my car, engine and electronics running with 2A...... could lead into runaway car ( out of range ).
There is Novak Lipo regulator with lipo cut off + LED for low batt signal.
Old 08-19-2008, 11:03 AM   #1908
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I do not know what amperage is needed, but I can say that I have been using 3 amps in my sedan and I used it in my IGT as well.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-19-2008, 12:00 PM   #1909
Ron C.'s Avatar
Originally Posted by Francis M. View Post
I still run NIMH.... It really is reliable and the 1400 mah pretty much could run a whole days practice.... ...
That is if you charge it..
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 08-19-2008, 12:08 PM   #1910
JayL's Avatar
yep, they have overheated within 4 race days....but we get 100+ degree F days
JayL is offline   Reply With Quote
Old 08-19-2008, 12:18 PM   #1911
Francis M.'s Avatar
LOL, It's always charged....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-19-2008, 01:44 PM   #1912
lil-bump's Avatar
Trader Rating: 83 (100%+)
I use the 1600mah NIMH Orion Marathon Keeps me running all day long.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-19-2008, 03:52 PM   #1913
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by CraigM View Post
Raising the lower pins raises the rear roll centre giving you more front grip. For a more subtle adjustment you can either add more shims on top of the rear hub (1mm makes a noticable difference) or use a lower mounting hole on the inner camber link
I will give it a try..thanks
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-19-2008, 09:00 PM   #1914
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
ok i know many of you ask this question but i need alittle help .... I'm running on a tight track with tight turns and i notice my car is pushing out of the turns just a tad bit any advice
thanks
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 08-20-2008, 05:14 PM   #1915
quietstorm76's Avatar
thanks
Post your setup. Is this for PT? What tires? need info
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-20-2008, 09:53 PM   #1916
bobbyblaze's Avatar
basically stock and the tweeks you made at the bowl... my first problem was it was spinning out on the turns you solved that...... now i think its pushing out...I'm running 37 shore front and rear at PT and parking lot track i use 40 shore
Old 08-20-2008, 11:06 PM   #1917
Arahawak's Avatar
Trader Rating: 32 (100%+)
Try a softer front spring than the rear or you could try 35 fronts 37 rears and 37 fronts and 40 rears at the parking lot.
By doing that you may want to soften the rear anti roll bar just enough for the rear to bite instead of swinging.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-21-2008, 04:39 AM   #1918
You could try 37fr 40r or
purple springs up front
front shocks in lower hole
Disconnect the front sway bar.
Just try one at a time.
Primary Weapon: ?
Secondary Weapon: ?
Old 08-21-2008, 06:28 AM   #1919
bobbyblaze's Avatar
Thanks Arahawak .......Marcos thanks too, just wish the bowl were closer for me to go but gas getting better now...but man i am driving the car more now and my goal is to rule primetime, mostly everybody there run NTC3 and they killing me not much on the tight turns after work at night i set up 50 cones at this parking deck in dalton but thanks again
Old 08-21-2008, 09:37 AM   #1920
Ron C.'s Avatar
thanks
Bobby,
Where do you have your Caster Settings?
Also, what steering ackerman do you have at the moment?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
