Old 08-18-2008, 12:05 PM   #1891
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by itchy b View Post
The Xcceed 1/8th Rx lipo is a great fit and can be found at RC Mushroom!
You sure? Lol that thing looks long!
http://rc-mushroom.com/product_info....ducts_id=14335
And then whats everyone using for a regulator?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-18-2008, 12:19 PM   #1892
shamu's Avatar
Originally Posted by quietstorm76 View Post
Raise the rear lower pins.
all the suggestions help but this makes a big difference
CHARLIE SCHAUMBURG
XRAY NT1 2013 / FORDHAM HOBBIES / HOT RACE TYRES/ Port Jervis NY Onroad Raceway/ FLOYD BENNET RACEWAY / McPappy Racing /
shamu is offline   Reply With Quote
Old 08-18-2008, 05:02 PM   #1893
itchy b's Avatar
Yes i'm sure!
I'm running this battery in both my MTX4s along with the Xcceed 6.2v regulator.
The reason the battery looks long, is that it is thinner than a regular 5 cell battery, but the length is fine!
Trust me!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-18-2008, 05:35 PM   #1894
JayL's Avatar
I have seen quite a few issue's with the current regulator's....try finding one in a 1hr a-main at a big race......
I am waiting to try the new orion 10a with heatsink
meanwhile my orion ni-mh 1600 last's for one- hour easy
JayL is online now   Reply With Quote
Old 08-18-2008, 06:01 PM   #1895
Yes i'm sure!
Trust me!
And you just tape it in the car? Any protection to it? I know a local here ran a common sense pack, and he had to put a piece of metal on the one end so it didnt hit the pulleys.
What do you mean? They blow up, or over heat? I want to run my day on lipos, or at least my practice day with no worries...
Old 08-18-2008, 07:32 PM   #1896
Francis M.'s Avatar
I still run NIMH.... It really is reliable and the 1400 mah pretty much could run a whole days practice.... I have no idea about lipo rx packs since I just run lipo on my electric sedan...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-18-2008, 08:22 PM   #1897
Arahawak's Avatar
Trader Rating: 32 (100%+)
You know it be quite a sight to see the car blow up in the middle of the track..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-18-2008, 08:48 PM   #1898
Ditto...got the same pack in mine, never had it die on me yet
Baedarlboo is offline   Reply With Quote
Old 08-18-2008, 09:41 PM   #1899
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
In the month of August alone, I have run a 60 min main and a 45 min main using a lipo and a Novak 3 amp regulator in my Kyosho sedan. Have run other 45 and 60 min mains. No problems yet.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-18-2008, 09:57 PM   #1900
Arahawak's Avatar
Question: Will running a Lipo Rx battery affect the cg? Do we have to compensate by using a brass battery tray then?
Old 08-18-2008, 10:27 PM   #1901
CraigM's Avatar
Trader Rating: 34 (100%+)
a lipo rx pack will be lighter so you will need to weigh your car to ensure it is legal. The CG would changed but I doubt you would notice it
Raising the lower pins raises the rear roll centre giving you more front grip. For a more subtle adjustment you can either add more shims on top of the rear hub (1mm makes a noticable difference) or use a lower mounting hole on the inner camber link
I'm interested if anyone has tried raising the height of the rear camber link (but not changing the angle) by using the top mounting hole on the inner mount and adding shims on top of the hub. I use a similar technique with my EP car and it helps to calm down the rear while having minimal effect on the RC
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-18-2008, 10:30 PM   #1902
Yes, it will alter the CG. I would add the brass battery tray (especially if the car is now under legal race weight) , or add brass to the chassis wherever you want. This will probably also allow you to lower your fuel tank if you want to.
Old 08-18-2008, 11:20 PM   #1903
Arahawak's Avatar
I have a fellow racer who had done that, changing to lipo and lowering his fuel tank, i think his servos were also lowered by another mm or 2. It has worked to a great effect having him coming up tops many times in our local races.
Question is how do i find the balance of the car if i switch to lipo? I remember something abt shifting the balance of the car will affect how the car drives.
Old 08-19-2008, 04:49 AM   #1904
Mugenville's Avatar
Trader Rating: 25 (100%+)
Using the Xceed lipo you should be able to drop the tank by at least 3mm not sure on other lipo's
Proud team member of "Team Mugenites" 2008 PDNR 2.4 Hr Victor's
Just finishing a race is a victory in itself
Jeremy Clarkson
"When you push a car past 180mph, the world starts to get awfully fuzzy. When you go past 200mph it actually blurs. The Bugatti Veyron is mind-blowingly, stunningly brilliant. It deserves 12 stars. Simply as good and as fast as it gets"
Mugenville is offline   Reply With Quote
Old 08-19-2008, 05:07 AM   #1905
RC MARKET's Avatar
KNACK
R CONV. KIT
RC MARKET is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
