Old 07-08-2008, 07:47 PM   #1741
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by tony montana View Post
I can easily spend the 40.00, but would rather send it on something like foams or other breakable parts. One thing I have always struggled with my mugen on road cars is with the steering servo. I always, always have trouble with the servo horn hitting the servo case when turning the wheel. I have tried triming the servo horn, spacing the servo nothing seems to work. With the servo out of the car it has tons of steering travel, with it in and the radio on and turning the wheels, I have half the steering travel. Any suggestions?
Not quite exactly sure what you are talking about. How about some pictures?
Some troubleshooting questions:
Are you using the correct servo spacers? There are spacers for different brands of servos..
Use a penknife to trim the ball ends connecting the steering servo and the servo saver.
Adjust the EPA on your radio.
If you have the money try getting Team AJ servo horns for Mugens.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-08-2008, 10:45 PM   #1742
lil-bump's Avatar
Trader Rating: 83 (100%+)
I use the Dubro horns. Use the long horn, but place the screw in the second hole from the end. Make sure you get the proper horn based on your model of servo. A hitec horn will not fit JR servo.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-09-2008, 07:26 AM   #1743
Bad Mika's Avatar
Default steering hub t0138-b & t0164
hi, sorry maybe this has been discussed before ...
what is the difference between the t0138-b and t0164 steering linkage besides it's obvious physical geometry ?
for each steering hub, for what type of track should i use ?
many thanks
Bad Mika is offline   Reply With Quote
Old 07-09-2008, 07:59 PM   #1744
tony montana's Avatar
Trader Rating: 66 (100%+)
the 164 front hubs are standard on the mtx4r. They are 2 degree hubs, the 138-b I think are 0 degree. Yeah Im using the dubro servo horns actually, I bought the kit for jr servos which Im using a jr 8450. I put the small short horn actually, so I should use the taller one?
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 07-09-2008, 08:39 PM   #1745
G87z's Avatar
I use the 138-B on my MTX-3. They seem to work well. I got some more steering while using them. The only mod I had to do was notch the lower arms so they would turn in completly. Are the MTX4-R arms notched in anyway? Does anyone have a pic they can take of the MTX4-R Arm? I thought the 138-b hubs were the 2 degree. I may be wrong though. What does the degree affect in terms of setup?
G87z is offline   Reply With Quote
Old 07-09-2008, 08:54 PM   #1746
Arahawak's Avatar
138-B are not 2 degrees hubs. the new kits have notches cut in already for the 2 deg hubs on the lower arms, that allows more steering.
The new hubs basically allows you to varies the steering grip on the front by placing the desired amount of washes.
Old 07-09-2008, 09:24 PM   #1747
lil-bump's Avatar
Yes, Use the long one. Just mount your eyelet in the second hole from the end. The short horn does not give enough steering throw
Elliott Hart
Serpent America
Desoto Racing Team
Old 07-10-2008, 06:48 AM   #1748
gentleman81's Avatar
anybody using that centax clutch tool on the mtx4? the one that u can adj from the outside.
does it work or is it a gimick? carlsen has some nice stuff
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 07-10-2008, 01:17 PM   #1749
Trader Rating: 21 (100%+)
Hey Craig I've got one, you can check it out Sun.
VA_Racer is offline   Reply With Quote
Old 07-10-2008, 03:35 PM   #1750
i had seen someone trying to use one and it didnt quite fit, but maybe the clutch nut was just mangled or something. sweet!
Old 07-11-2008, 04:58 PM   #1751
yeah, Thats the problem is Im lacking steering throw with the short servo horn, Didnt realize the shorter one could have been the problem, I will try the longer one, thanks for the tip
Old 07-11-2008, 05:04 PM   #1752
itchy b's Avatar
So which way does it work with the 2 deg hobs?
More washers = less steering
Less washers = more steering
Or is it the opposite?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 07-11-2008, 06:40 PM   #1753
Arahawak's Avatar
You are right.
Old 07-11-2008, 06:40 PM   #1754
Im in the process of getting universal for my mtx4. Does anyone have a way to prevent the dogbones from falling out after a crash or at full steering throw? I did cut some fuel line to about 10mm for the front ones, think that will take care of it, or should I do something else
Old 07-11-2008, 06:44 PM   #1755
Arahawak's Avatar
That's the best so far besides changing to universals. You may also want to use cable ties and secure them to the arms to prevent from losing them in case of a crash.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
