Old 07-06-2008, 12:54 AM   #1711
Originally Posted by tony montana View Post
do have the belts set to tight ot loose? 2 belts seem a little odd but I can understand going threw 1 in a gallon
I have the tention set as per manual. How can I tell if it s too tight or too loose?
sllo is offline   Reply With Quote
Old 07-06-2008, 05:50 AM   #1712
tony montana's Avatar
Trader Rating: 66 (100%+)
you should be able to have a little up and down play, not alot but a little. You didnt get a hlod of a rock did you. QUuick question, can I make a spool out of the one way that is included in the kit? I really dont wanna spend 4o bucks on the spool and was hoping someone could suggest a way of doing it with the one way.
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 07-06-2008, 07:42 AM   #1713
Well, guess what, I stripped my second gear yesterday. Bad thing is I was only tuning the engine on the starter box for about 3 minutes and I noticed hearing a noise. So Im stumped like the rest of you guys now
Old 07-06-2008, 11:02 AM   #1714
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
You dont need to spend 40 bucks to get a spool... You can use a diff casing with a block instead of gears to create a spool. Im going to warn you that if you use the casing provided by mugen (the plastic one), it might strip. You can try using 3racing's one which i believe is like $15 bucks.
Other thing you can do... Is use epoxy and glue the outdrives into the one way. Or if you can manage your way into getting a power drill and drilling two holes into the one way so you can place pins in order to stop the outdrives from moving is another way to convert it to a spool. Hope this could help.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-06-2008, 11:24 AM   #1715
yeah I thought about drilling the holes in mine but Im wondering what to use to hold the pins in and where to get pins
Old 07-06-2008, 01:15 PM   #1716
The oneway that is in the kit can be converted into spool. It has holes to put pins and lock it and there are 2 big orings tha hold the pins. At least that is how mine is.
Old 07-06-2008, 02:38 PM   #1717
Riketsu's Avatar
I believe he has the one-way, not the one that can be converted into a spool.
Old 07-06-2008, 03:48 PM   #1718
yeah I just have the oneway now. I had a mtx4r and was running the spool up front. Like a idiot I sold it. And my 4r drove much better to me with the spool in stead of the one way. Right now I just have a regular mtx4
Old 07-06-2008, 04:43 PM   #1719
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
check this out it for sale ready to go just need rec. and rec. batt.. item # 280242797509 make me and offer
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 07-06-2008, 05:16 PM   #1720
wanna sell just the front spool?
Old 07-06-2008, 05:21 PM   #1721
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Arahawak View Post
FLushed, prob that's why it is causing the strip..
I looked at a friends 2 speed housing and his bearing was flushed. I pushed mine in all the way and gotta see if the problem is gone. I hope it was that simple.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 07-06-2008, 05:22 PM   #1722
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
do anybody run the ajustable sway bar on their car .....is it worth buying ?
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 07-06-2008, 05:40 PM   #1723
I thought about buying it, but I think its over priced
Old 07-06-2008, 05:54 PM   #1724
Rc_Boy89's Avatar
Send a message via MSN to Rc_Boy89
+1
Im still using the standard rear sway bar setup, it works fine. I don't really see any real big advantage running the blade type.
.:Team Extreme:.
Kyosho STRR / OS Speed
Mugen MTX-4R / RB Speedline Matrix
Jammin CRT.5 / Sirio STI
Rc_Boy89 is offline   Reply With Quote
Old 07-06-2008, 06:27 PM   #1725
Riketsu's Avatar
When i used to run the MTX-4, i never changed the wire roll bar. Now with the Kyosho RRR, i changed the blade to wire too.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
