Old 07-03-2008, 07:16 PM   #1696
quietstorm76's Avatar
Originally Posted by nitrobeast View Post
Do you mean set it up so the arm lean down when looked at from the side...
I think its called pro-squat?
No.... both front and rear inserts are in the same position.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 07-03-2008, 08:27 PM   #1697
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hey
I was wondering why you wanted another one...Its been good as of now, but i think it gonna strip the second gear soon. Did you have problems with that too? Im on here looking for the pic someone posted on how to fix it...
I have 2nd gear stripping problem and till date i still do not know what is the problem. I have changed and check everything from bulkheads, bearings, clutch bells, gear meshing, engine screws mounts, stiffer chassis, single engines mounts.. but still strip.
But i am trying the new spurs and 2-speed thing and it seems to last a little longer. I wonder if there was any quality issue with the older spurs.
Hope this helps.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-03-2008, 08:28 PM   #1698
Arahawak's Avatar
Is the bearing in the housing suppose to stick out a little or be flushed with the housing? Not sure how its suppose to be since i bought the car used...
FLushed, prob that's why it is causing the strip..
Old 07-04-2008, 05:13 AM   #1699
JetMD's Avatar
I tried every suggestion everyone had and nothing fixed it until I bought a 4mm chassis. Now I can even put a little slop in the mesh and it still won't strip.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 07-04-2008, 09:34 AM   #1700
tony montana's Avatar
Trader Rating: 66 (100%+)
yeah I did strip one actually. Try the new mugen spurs, suppose to be harder material. Also make sure you set the mesh with 1st gear off the car. Another suggestion make sure the screws that hold the engine mount are totally square with each other
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 07-04-2008, 09:52 AM   #1701
yodace's Avatar
R/C Tech Charter Subscriber
what throttle servo u guys recommend?
yodace is offline   Reply With Quote
Old 07-04-2008, 01:07 PM   #1702
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Default MUGEN MTX4R race ready
Hi I'm selling my MUGEN MTX4R with Ninja .12 Ninja Pipe the good one the twist and lock one also both srevos Airtronics $119 ones spare parts 2 Ti shafts all lite MSR pullies oneway and lock diff. Check it out on ebay item # 280242797509 thanks [email protected] REASON FOR SELLING MY LOCAL TRACK IS NOT RUNNING ANY NITRO FBF IN BROOKLYN
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 07-04-2008, 11:00 PM   #1703
Mugenville's Avatar
Trader Rating: 25 (100%+)
Anybody using a lippo as there RX pack, if so what Mah and what are the dimensions of the pack, looking at using one in the not so distant future
Cheer's Rob
Proud team member of "Team Mugenites" 2008 PDNR 2.4 Hr Victor's
Just finishing a race is a victory in itself
Jeremy Clarkson
"When you push a car past 180mph, the world starts to get awfully fuzzy. When you go past 200mph it actually blurs. The Bugatti Veyron is mind-blowingly, stunningly brilliant. It deserves 12 stars. Simply as good and as fast as it gets"
Mugenville is offline   Reply With Quote
Old 07-05-2008, 03:59 PM   #1704
What can cause the rear belt to strip? I lost 2 rear belts in one gallon of fuel.
sllo is offline   Reply With Quote
Old 07-05-2008, 04:39 PM   #1705
do have the belts set to tight ot loose? 2 belts seem a little odd but I can understand going threw 1 in a gallon
Old 07-05-2008, 05:37 PM   #1706
YLLIB's Avatar
Hope this helps.
I would still buy the 4mm chassis from Mugen or the Kawahra that Mugen sells. I also woukld try buying the YBSLOW chassis brace KIT, that workes well at least at our track. (speedworld) my2cents
YLLIB is offline   Reply With Quote
Old 07-05-2008, 05:40 PM   #1707
YLLIB's Avatar
Whats up Big Dog, this is Billy from SpeedWorld. Why are you selling. PM me and tell how much you want for it. We are Mugen and Serpent country out here. I still keep trying to push the NT1 & Kyosho out of the store. I like it to have a little of everything racing at the track.
Billy
Old 07-05-2008, 06:25 PM   #1708
chippy's Avatar
Cheer's Rob
Hi Rob
Iam using the Xceed 1300mah 2cell pack fits in the car easy
Dont no the actual size
But can measure next time I have it out of the car.
You will also need the 6.2v regulator
Lance
chippy is offline   Reply With Quote
Old 07-05-2008, 06:59 PM   #1709
Mugenville's Avatar
Originally Posted by chippy View Post
Hi Rob
Lance
Lance where you get them from and how much damage is it going to be , just got my new Radio (T3pk with spektrum) came with a lippo batt, but noticed it doesn't have the balancing lead fitted, got te car sort of sorted out now, was clutch settings, replaced with ultra hard spring, grey shoe and also fitted the new option 2 speed, seems fine now and the engine sounds a whOOOOOle lot better
Jeremy Clarkson
Old 07-05-2008, 09:14 PM   #1710
chippy's Avatar
sounds good Rob
Shoot me a pm with your email addy and Ill forward you the details
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
