Mugen MTX-4R
Old 06-25-2008, 01:08 AM
  #1681
asw7576's Avatar
Hey, that's right...... my mtx4 has understeering tendency too at mid corner. And it can understeer even more if I enter the corner too fast. I have to let go the gas quite early, so the car won't overshoot the apex. Oh well.... I haven't find the perfect setup yet ......, coz other cars ( without this problem ) are able to whoop ass
Perhaps I should consider cutting lower rear and front suspension arms to make it short wheelbase.
Currently I put 60,000 diff oil in rear, and I haven't test it yet.
I'm speculating the mid cornering can be tighter after using 60K diff oil.
asw7576 is offline
Old 06-28-2008, 08:24 PM
  #1682
bobbyblaze's Avatar
i need a little help my car is loose coming out the corner ...what can i do to solve it
bobbyblaze is offline
Old 06-28-2008, 09:15 PM
  #1683
asw7576's Avatar
use less downstop for rear ( lets say from 4 to 3 ) and/or do the opposite for front ( lets say from 0 to 1 ) <----- 4th
use 3 degree toe in for rear tires <----- 2nd
lay down the rear by one more hole <----- 3rd
use fresh tires <----- 1st try
asw7576 is offline
Old 06-29-2008, 01:24 AM
  #1684
what do you mean?
sllo is offline
Old 06-29-2008, 01:41 AM
  #1685
Mugenville's Avatar
Trader Rating: 25 (100%+)
Originally Posted by sllo View Post
what do you mean?
drop your shocks down 1 hole on the shock tower (Rear stay)
Mugenville is offline
Old 06-29-2008, 03:09 AM
  #1686
choisan's Avatar
heard a rumor that there will be an upgrade kit, which is same as mrx4r become a "x" for the mtx-4r, anyone heard that?
choisan is offline
Old 06-29-2008, 07:56 AM
  #1687
tony montana's Avatar
Trader Rating: 68 (100%+)
I have heard no rumor of a mtx4x. I think mugen is busy working on there new mbx6 buggy.
tony montana is offline
Old 07-02-2008, 04:09 AM
  #1688
nitrobeast's Avatar
Trader Rating: 42 (100%+)
Got to drive my mtx4r for the first time and it was decent out the box...Had a little push mid/corner out on power but other then that it felt great.... I was able to go in hard but had to brake hard to keep the push down..
Does anyone know what shore the stock tires are?
nitrobeast is offline
Old 07-02-2008, 04:36 AM
  #1689
nitrobeast's Avatar
When you say less you mean more droop? Lower number on the gauge?
Old 07-02-2008, 06:49 AM
  #1690
spenzalii's Avatar
I believe the stock tires are 37 shore all around in the kit,
spenzalii is offline
Old 07-02-2008, 05:45 PM
  #1691
nitrobeast, whats up man, How is the 4r treating you? I missed it so much I had to go and buy another one!!! yeah the kit tires are 37 shore. It may be pushing because I had 30,000 in the rear diff
Old 07-03-2008, 04:56 AM
  #1692
nitrobeast's Avatar
Hey
I was wondering why you wanted another one...Its been good as of now, but i think it gonna strip the second gear soon. Did you have problems with that too? Im on here looking for the pic someone posted on how to fix it...
Old 07-03-2008, 11:01 AM
  #1693
quietstorm76's Avatar
Have fun with the box setup. Save yourself the headache and change the rear lower pins to the middle or up position.
quietstorm76 is offline
Old 07-03-2008, 03:48 PM
  #1694
nitrobeast's Avatar
Do you mean set it up so the arm lean down when looked at from the side...
I think its called pro-squat?
Old 07-03-2008, 03:52 PM
  #1695
nitrobeast's Avatar
Default 2nd gear housing
Is the bearing in the housing suppose to stick out a little or be flushed with the housing? Not sure how its suppose to be since i bought the car used...
