Old 06-16-2008, 05:49 PM   #1636
Seisick's Avatar
don't know wich futaba servo do you
have but on my digital i use original
servo arm and use body reamer
to enlarge the hole
works fine in more than 2 years with my
mtx4
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-16-2008, 06:46 PM   #1637
Trader Rating: 21 (100%+)
this is in my opinion the best servo horn for that servo.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFVM2
VA_Racer is offline   Reply With Quote
Old 06-16-2008, 07:25 PM   #1638
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Originally Posted by SasonRC View Post
MUGEN Gurus:
I have just bought me a second hand MTX4-R. While going through a clean and rebuild project I got stuck when adding the steering servo. I have the parts to add the servo but now I am having a little difficulty attaching the servo saver to the servo arm. My problem... I don't know what servo Arm to use. I am using a futaba servo.
I have cut out some of those cross horns that come with the servo, plus I had some OFNA arms from prior kits, but the length sometimes it's too long and making holes is reducing my stock.
I am sure it's a simple answer but I am stuck. Please Help. I am sure I will have more questions as I continue my rebuild.
This might help you
http://www.amainhobbies.com/product_...ducts_id/19312
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 06-16-2008, 08:20 PM   #1639
gentleman81's Avatar
this is also what i use. i did trim it tho
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-16-2008, 08:41 PM   #1640
Old 06-17-2008, 10:31 AM   #1641
JayL's Avatar
Yep, the thin blue real futaba ones are strong. I had one of the thicker silver ones tower sells and it was easier to cut/dremel than the thin blue one, lol
JayL is offline   Reply With Quote
Old 06-17-2008, 12:04 PM   #1642
Originally Posted by chippy View Post
Kawahara chassis lighter and a lot cheaper
I have used the Kawahara 1 with no problems
The kawahara pro is a 4mm chassis is it milled like the 4mm of Mugen?Meaning it has groove for the bulkheads.
trebronpay is offline   Reply With Quote
Old 06-17-2008, 03:39 PM   #1643
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default Shock length
I set my droop at 2 without the shock and sway bar. I added the sway bar and my droop stayed at 2. When i put the shocks on the droop is now at 1. Are my shock too long or is this ok? This is the front by the way.
What should front and rear shock length be?
Also how much steering in degs are you guys getting? Im 22 deg both ways with 1 deg toe out
thanks for the help
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-17-2008, 04:00 PM   #1644
that should be correct, that is why you set the droop minus the shocks etc. because the shocks press the arms down further
Old 06-17-2008, 04:58 PM   #1645
nitrobeast's Avatar
Thanks!! What about the shock length?
Rui Goncalves
Old 06-17-2008, 05:20 PM   #1646
CraigM's Avatar
Trader Rating: 34 (100%+)
it depends on your rebound
by the way you should set your droop with the sway bar disconnected, then add the sway bar and ensure it stays the same - if not your sway bar is tweaking your car. Then add the shocks and repeat the process
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-17-2008, 05:33 PM   #1647
nitrobeast's Avatar
Thats the way I did it, thanks
I dont understand what you mean about the rebound?
Rui Goncalves
Old 06-17-2008, 07:30 PM   #1648
itchy b's Avatar
Yes it is milled out for the bulkheads and also in other places as well to remove unneeded weight, but the best bit is that its milled out in the whole area of the engine bay (unlike the mugen 4mm chassis) which allows the use of the Kawahara one piece engine mount if so desired!
It's also only 1 gram heavier than the standard mugen 3mm chassis!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-17-2008, 07:55 PM   #1649
what is the best way to get the car to rotate in the turns? my car kinda stops like a clock ticking in the turns
Old 06-17-2008, 09:36 PM   #1650
i have a mtx4 converted to R. weighed in at 1725g at the cap classic.
4mm mugen chassis
universals all the way
stock shafts
stock screws
front mugen multi diff
if i put in a full TI screw kit, not pillowballs and light weight shafts, which battery tray should i get?
43 or 60g?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
