Like Tree1Likes
Mugen MTX-4R
Old 06-02-2008, 10:11 AM
  #1591
Seisick's Avatar
kyosho has 5x7 shims, they come in .1 .2 and .3 thick
as long as you use this to space the 5x8 bearings it will be fine!
serpent and xray have easy instructions on how to assemble properly
the centax and also the theory regarding the effects of gap, endplay, tension
shoe, and weights!
Seisick is offline
Old 06-02-2008, 11:06 AM
  #1592
JetMD's Avatar
I also use the kyosho shims for this. They work great and come in the exact sizes you need.
JetMD is offline
Old 06-02-2008, 11:24 AM
  #1593
Canuck's Avatar
Trader Rating: 25 (100%+)
You got a part number for the Kyosho shims ?
Canuck is offline
Old 06-02-2008, 11:55 AM
  #1594
96643
http://ashfordhobby.com/detail.aspx?ID=428
neltime64 is offline
Old 06-02-2008, 01:19 PM
  #1595
I'm actually using a 2mm thick 5x7 Schumacher spacer, that's used in their touring car hubs between wheel bearings and then I have to add some 0.1mm shims to get it perfect. Since I put the shims on the flywheel side of the 2mm spacer, they don't have to be small OD and I use normal clutch shims for that.
olev is offline
Old 06-02-2008, 01:21 PM
  #1596
Canuck's Avatar
I like this solution ! I am pretty sure I have a similar 2mm shim in my spare parts.
Canuck is offline
Old 06-02-2008, 02:47 PM
  #1597
JetMD's Avatar
Originally Posted by neltime64 View Post
Those are the ones I use. Didn't know the part number though. Need some more for a 1:8 that I just got.
JetMD is offline
Old 06-02-2008, 03:43 PM
  #1598
gentleman81's Avatar
i was showed by a good man to use the thrust bearing shim, is has worked for me. i believe it does translate into more heat build up in the bearing tho. because the bearings seem to need more maint. and replacing
thats just my 2 cent
gentleman81 is offline
Old 06-02-2008, 06:39 PM
  #1599
Gseventeen's Avatar
Inside start with 1.18 thrust bearing shim,then just add smaller shims untill endgap is0.10, remember inside shims change only endgap not clutchgap,to get clutchgap take all iside bearings and shims out.Put bell and thrustbearing on onlythen measure gap holding bell against clutch shoe, say gap is0.90 then add 0.20 shims this will give you 0.70 clutch gap, then its just testing spring nut to determain engagement smoothness or sudden. Easy Peasy (NOT)
Gseventeen is offline
Old 06-03-2008, 12:44 PM
  #1600
lil-bump's Avatar
Trader Rating: 85 (100%+)
Is the NitroKB site ever coming back????
lil-bump is offline
Old 06-04-2008, 04:09 AM
  #1601
dead set, stop jibbering and get a NT1!
TomB is offline
Old 06-04-2008, 04:15 AM
  #1602
Canuck's Avatar
Great reply ! My problem was that I was trying to get a GAP of .5mm without removing the endgap shims !!!!!!!!!!
Canuck is offline
Old 06-04-2008, 05:21 AM
  #1603
nitrobeast's Avatar
Trader Rating: 42 (100%+)
Do you use the out side bearing, the one by the thrust bearing when setting clutch gap?
Also are the bearing 5x8x2.5
nitrobeast is offline
Old 06-04-2008, 07:08 PM
  #1604
Gseventeen's Avatar
Thats a double YES!!!
Old 06-04-2008, 07:11 PM
  #1605
Gseventeen's Avatar
LISTEN VADER!!that so called jibber is straight out of the(DARKSIDE) emanual OOPS!!!
