-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Pros Vs. Cons of Rubber Vs. Foam tires (https://www.rctech.net/forum/nitro-road/157519-pros-vs-cons-rubber-vs-foam-tires.html)
wes95_z28 04-04-2007 11:28 PM
Just wanting to know your opinions, old friend of mine a long time told me that foam tires on a nitro touring car were the way to go, he said that they provide allot more traction than rubber tires. I have been using foam tires ever since and from the get go i wasnt real crazy about them. they just drive weird, and dont seem to hook up at all. Do keep in mind i just run mine in a parking lot i dont run on any prepared surfaces at all.
rezenclowd3 04-05-2007 12:04 AM
Hehe, trying those foams out that were in the package you bought? If you are, those were for running on Revelation Raceway in Ontario, which is super sticky, high traction. They wont hook up in parking lots at all, as they are way too hard.
wes95_z28 04-05-2007 12:09 AM
i knew something was up with em when they make almost as much traction as the hard drift tires lol. i am very used to those hpi Rally tires though, the track i race oval at uses those as the spec tire i know what those will hook up on. And what is up with the mess the foam tires make???? that is horrible lol.
wes95_z28 04-05-2007 12:11 AM
i did put the one way in it though and that is just to fun the great part about it is once your get the rearend hung out you can just nail the throttle wide open and it holds its drift pretty nicely.
Dredd 04-05-2007 12:21 AM
in a parking lot where there's oil and junk from cars on the surface, nothing will grip.
Dynamite 04-05-2007 12:33 AM
foam tyres rock for nitro ;)
stefan 04-05-2007 03:26 AM
Have been thinking very hard, but I can't come up with any pro's for rubber tires at all..... :cool: ;) :D ;)
cdelong 04-05-2007 03:48 AM
for parking lot racing you need like 35 shore foams to hook up. permanent tracks will need 37- 45 depending on conditions.
rubber tires just plain stink! you're stuck with a given diameter, the glue sometimes degrades and the rubber shreds from the rim (which is fun), and they cost more and get less runtime than foams.
once you get the right compound foams you will be happy. try 35 rears and 37/40 front's for parking lot bashing.
Powered By: vBulletin v3.9.3.6
