crank rust
whats the best way to remove rust from the crank and motor? please help.
Re: crank rust
Originally posted by integ32 whats the best way to remove rust from the crank and motor? please help. bit. Set the speed to low to medium and just dab it where you find the rust making sure not to press too hard. Also make sure to keep a steady hand because the circular motion can throw off the tool and may hit the metal to metal parts.. Hope this helps.. |
Re: crank rust
Originally posted by integ32 whats the best way to remove rust from the crank and motor? please help. and prevent the rust build up from happening again. This is mainly caused by left over fuel inside the motor after the motor has been ran and then kept. Try to make it a habit to, after each day of running the motor, to drain all the fuel from the tank and have the motor run off all remaining fuel until the motor dies out. This will insure that no fuel residue remains inside the motor which causes the rust that you are encountering. Some other people run the motor at idle and then pinch the fuel line to cut off fuel supply. Personally, I use the first method. It may likewise be a good idea to use After Run Oil after running out all the fuel. This will help lube the inner parts of the motor and keep it in shape for longer period of time. Hoep this helps further. :) |
integ32;
You can remove it as 'jwf-ronni' has suggested. But it is my experience that the bearings will also have rust in them and when you start the engine, this rust will come out and be sent through it causing damage. (This is very good example of the reason for running the tank dry and using after-run oil.) |
what kind of fuel were you using before this happened
i have in the past been known to be quite lazy with my maintenance for the last 2 years i didnt even own afterun oil (i do now) and i still dont drain tank always like im supposed to (i am trying to remember) but i have never had anything rust inside one of my engines to my knowledge using mainly trinity fuel but i have a friend who nearly ruined a new engine due to rust while using odonnel fuel when i check my engines now after a day of running they are full of oil from the byrons fuel |
Originally posted by jason102276 when i check my engines now after a day of running they are full of oil from the byrons fuel |
Generally it ISN"T the fuel - if O'Donnell were a bad fuel then it wouldn't be one of the best selling fuels out there. I've been running it for several years without any problems.
The problem probably is that the fuel is old or has been sitting out or unsealed. Methanol is hydroscopic meaning it attracts and absorbs water. Nitromethanol is even worse. So, if you leave your fuel open it's going to become waterlogged. Even if you leave it open for 20 minutes it's gotten some moisture in it. If you live in a humid climate it's even worse, for obvious reasons. Best bet is to a: keep your fuel bottle sealed, b: keep as little air in the bottle as possible and c: keep as little fuel in and around your motor when you're not running it. Don't blame the fuel. |
