Old 04-03-2007, 04:09 PM   #1
rmdhawaii's Avatar
Default Active Hobby Atenza SR (200mm) Body
Aside from rcosmax, has anyone else run this body yet? Mine in sitting in a bag waiting to be painted. How does it compare to the Mazda6? Any tips on wing placement?
Thanks!
Yes, I know it's not ROAR legal - it's just for club racing.
BTW... If you're interested. I have more pictures of the body in and out of the bag here.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 04-03-2007, 04:33 PM   #2
Sweet....where did you order it from?
Thanks,
Nel
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 04-03-2007, 04:48 PM   #3
rmdhawaii's Avatar
Thanks,
Nel
I ordered it from RC Adviser Champ in Japan. Since Axial is going to be carrying the Active Hobby product line, I'm wondering if you'll be able to get it through an Axial dealer in the near future.
Old 04-04-2007, 12:24 AM   #4
razzor's Avatar
Looks good ,kinda like the East Coast Mugen Accord R.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 04-05-2007, 06:09 AM   #5
i've had this body for a while now, it's sort of a werid one.... it isn't as stable as my protoform stratus all purpose, and it doesn't have as much initial steerign either, but on exit, the rear end keeps rotating, and the front stays steering as opposed to settling in through, and on exit of a corner.
the all purpose through the s sections at my local track was a lot more settled and relaxed on the s section compared to the active spr.
i setttled the car down a fair bit using the option active rear wing, but still it was not as good as the all purp stratus. On a fast flowing sweeper after a straight the spr rear end kicked out whilst the all purp was smooth and stable.
my conclusion is that the front actually has too much downforce my body was also infact mounted towards the rear quite a bit (ie less overhang on the front wheels), so i should of had alot more rear end downforce.
it looks sweet though!
Active Hobby Atenza SR (200mm) Body-active-body6.jpg   Active Hobby Atenza SR (200mm) Body-active-body5.jpg   Active Hobby Atenza SR (200mm) Body-active-body1.jpg
TomB is offline   Reply With Quote
Old 04-05-2007, 01:46 PM   #6
rmdhawaii's Avatar
TomB ~ Nice paint job! Thanks for for the feedback. I'm hoping the SR is a bit more stable.
The paint job in the photos is what I think makes the body so inviting. Too bad it doesn't come that way. It caught my attention while I was browsing some photos from the 2006 FEMCA championships.
The front end on the Type-M and the SR/SP-R are somewhat similar. What I noticed with the Parma Type-M at the time I tested it, was that the rear end was a lot looser than the Mazda 6 that I usually run. Your conclusion about too much front downforce may be right on the mark.
We'll see how it works out. I run a different setup these days, so it might be better. I should throw on the Type-M and see if the rear end is still loose.
Just FYI for everyone else, there are two versions of the Atenza body - SR (which I have) and SP-R (pictured below). With that fancy paint job, it's hard to tell them part.
Old 04-05-2007, 02:07 PM   #7
RC MARKET's Avatar
In FEMCA was TQ A1
http://rcmarket.com.hk/product_info....roducts_id=163
RC MARKET is offline   Reply With Quote
Old 04-05-2007, 02:22 PM   #8
razzor's Avatar
We ran a few bodies back to back on my G4s's a while back.
Protoform Stratus 3.1
Protoform Mazda6
Protoform Nemesis
Blitz Mazda6 2.0
Blitz Mazda3 2.0
Blitz TC 2.0 (Stratus)
Of these bodies the best steering and balance was the Mazda3
next was the Blitz TC and Protoform Stratus and Blitz Mazda6 all with good balance and decent steering.
The Nemesis was a surprise with its high speed handling.
The Protoform Mazda6 was a bit on the tail happy side coming out of corners and had some understeer going into corners ,was definately a hand full to drive.
While the Mazda3 and Stratus are favourites i must admit that this comparison was on the day with a car setup with Mazda3 body on it.
Guess if car was setup on another body ,outcome would posibbly be different.
But all the guys that have run the Mazda3 find it is more planted and has good steering.
We dont have many makes of bodies available and the Protoform are more popular especially the Stratus and Mazda6.
Casterracing ZX1.5R
Old 04-05-2007, 02:52 PM   #9
rmdhawaii's Avatar
Thanks razzor.
I ran the Protoform Status recently on an MTX-4 and it was pretty neutral. It took quite a bit of extra power on exit to get the back loose. Depending on how things go with the Atenza, I will probably try the Blitz Mazda 3 next.
Old 04-06-2007, 01:18 AM   #10
kcrunchone's Avatar
I have run the body several times and have felt that it gives similar handling to the Mazda6 but the aggressiveness steering that the 300 body. It is a very good body that I found even on a semi rough to smooth track held its own. I would say that it did perform a bit better on the rougher terrain tracks allowing the car to seat and plant the rear allowing me to have a loser set up in the rear to swing the car into the turns allowing power-slides with little offset to the balance of the steering.
DO not set the wing to far to the rear keep it more aligned with the rear of the body to gain the better characteristics mentioned. That was on Kissimmee track and Cincinnati but you can make other holes on the wing. I made three sets. Forward center and rear positioning. Test them out and see what works best for you.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 04-06-2007, 04:06 PM   #11
rmdhawaii's Avatar
Thanks Rick
Old 04-07-2007, 01:54 AM   #12
razzor's Avatar
have to agree with kcrunchone the rear wing placement makes a noticeable difference.
I set with wing lined up with rear bumper and go one hole back from there.
I just love the steering from the Mazda3
Casterracing ZX1.5R
Old 05-07-2007, 12:31 AM   #13
rmdhawaii's Avatar
Ran the body on my MTX-4 today with Kawaharas (not the Jacos as shown below) and it was awesome. It was really stable and provided just the right amount of steering. Full-throttle drifting through the sweeper leading into the straight was very predictable and the car just planted itself once the wheel were pointed straight. This body is great. I highly recommend it.
Old 05-07-2007, 02:02 AM   #14
itchy b's Avatar
Great to see you found the body to help you get the best out of the Mtx4
Does this mean that you will be making the Mugen No.1 in your stable now?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-07-2007, 02:32 AM   #15
razzor's Avatar
Casterracing ZX1.5R
Active Hobby A210SS / New "Lancia Stratos" body !!! zenithrr Electric On-Road 1 05-19-2008 08:52 AM
A210ss Active Hobby Touring Car chicagokenji Micro and Mini Scales 4 05-08-2008 01:58 PM
Active Hobby bodies charlesd Nitro On-Road 1 07-29-2007 06:21 AM
Active Hobby - Mini 4WD fleagun Australia For Sale/Trade 6 03-12-2007 11:15 PM
Active Hobby in Japan AMGRacer Nitro On-Road 12 09-13-2003 05:29 AM
