Old 04-02-2003, 05:35 PM   #1
skibum989's Avatar
Default Base needle settings (MT-12)
Here's a little bit of trivia:
Does anybody know what the base needle settings for a Nova .12 slide carb (namely the one on my Mugen MT-12) are?
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 04-02-2003, 11:16 PM   #2
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Mid needle (bit bronze that is so tempting to turn) - flush! Don't touch it if you haven't already. . .
High needle (from fully tightened) - 5 out
Low needle (from fully tightened) - 3 out
Tune from there. That should be at least pretty close.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 04-05-2003, 03:24 PM   #3
Send a message via ICQ to Cartman
Default Re: Base needle settings (MT-12)
will run good (if run in) main 4 turns out, mid flush, low 2.5 out. when doing low open throttle wide and screw in, this prevents damage.
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 04-05-2003, 06:34 PM   #4
Korey Harbke's Avatar
Hey Skibum,
Cartman is right. His 4 on top, middle flush, and somewhere between 2.5-3 turns out on the bottom. I came up with 2.75 turns out on mine, but I have a MR-12 not a MT-12. Do that trick where he tells you to open the throttle all the way. Now my motor is too fast for my own good. I might be backing off the centex to engage earlier to make it a bit easier to control.
-Sushi Boy
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-08-2003, 09:49 AM   #5
Boomer's Avatar
Yep - 4 and 2.5 are closer to my fully tuned motor (actually, I think they're spot on!) but when I go back to "basic" I go back to a richer setting and lean it from there. . .
Old 04-08-2003, 04:38 PM   #6
Yeah, I usually do too, but the instructions that came with my motor didn't even have any starting needle points at all. All they siad is break it in at the factory settings, but I richened tem up a bit anyways. I had no idea where to start.
Old 04-08-2003, 04:49 PM   #7
same here - my RS12S1 factory needle settings were GUSHING rich - fuel almost filled the pipe! i kept turning them in and found that it's pretty good at 3 main 2 low - might even be a little lean for only 7 tanks thru it but it still puts out smoke - even when shifting to 2nd...
and the manul really dosen't have any needle settings (imagine that) - in fact the manual has no page numbers.
cybertoolzz is offline   Reply With Quote
Old 04-09-2003, 12:29 PM   #8
ottoman's Avatar
This is a little off topic, but... where is a good place to order a piston/sleeve and con rod for a MT12?
ottoman is offline   Reply With Quote
Old 04-09-2003, 02:04 PM   #9
I think www.horizonhobby.com had some. I think Speedtech has some too.
Base needle settings for 427 badaml Nitro Off-Road 3 10-15-2007 08:42 PM
base needle settings on novamega sx12 ss charlesd Onroad Nitro Engine Zone 0 10-01-2007 07:34 AM
YO HELP MR Ninja MR21 B01 engine base needle settings? nobike Electric Off-Road 17 04-08-2007 08:15 PM
MR Ninja MR21 B01 engine base needle settings? spinall4 Electric Off-Road 13 12-20-2006 08:53 PM
Raptor base needle settings shodokai7 Monster Trucks 0 07-24-2005 11:05 AM
