Old 04-02-2007, 11:57 AM   #1
MRX4-R03's Avatar
Default How do you guys set up your centax clutch..
I just wanted to see how some of the guys here set up there centax clutch system and the what do they use for there preload and bearing clearence..
so people say use .50 of clearence and some say use .40-.30 I think this will be some good info like the clutch bell thread..
MRX4-R03 is offline   Reply With Quote
Old 04-02-2007, 02:37 PM   #2
bvoltz's Avatar
Trader Rating: 44 (100%+)
It will be interesting to see what others say...
But I use .01 of clearence, but I shim the bell from touching the shoe. when you push on the clutch bell and turn it. My opionion on this, is I want a little clearence as possible to not drag the clutch bell on the shoe.
Preload, I use 9.5 to 9.6 mm, measuring from the end of the crank shaft to the nut holding the spring in place. It slips a little much for the first lap or two, but then comes in very nicely. I also lighten the clutch weights a bit, on the RRR assembly, I take the holes out to 4mm.
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-02-2007, 03:12 PM   #3
lil-bump's Avatar
Trader Rating: 83 (100%+)
I shim the clutch bell until it no longer drags. I set my spring preload at .5mm and adjust from there. I tried Mike Swaugers settings. The clutch engaged way too late
(I guess I need a $300+ motor to use his settings). My endplay is set to .2mm.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-02-2007, 04:03 PM   #4
MRX4-R03's Avatar
how are you guys getting your clearence, what tools are you using..
Old 04-02-2007, 04:37 PM   #5
Seisick's Avatar
go to mytsn.com and download the manual for the 720, theres a good explanation on how to adjust the gap and the endplay, you could shim and have no drag on your shoe, but that does not mean it is the gap.
.6mm gap and .1 .2 are common choices. and the preload changes from every engine manufacturer and varies according to the flywheel cone and the flywheel itself and if you are using a shim behind the cone, so that measure should be only valid from the top of the cluth nut, not the shaft.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 04-02-2007, 04:39 PM   #6
I set it by feel. Basically I eyeball it, then go run it for a bit. How does it feel? I don't measure it often and usually don't have to. I can usually tell by feel and the amount of play on the clutch bell. Just for refrence though I started with .5mm and worked from there. My clutch feels like it slips alot when you first get going, but once it warms up it's like a gun and you really gotta be careful. I think this is basically how they all should be. You really shouldn't be able to move it much right away, and it would seem like it's going nowhere. Blip the throttle a few times and it gets going. After the first turn it's gonna take off every time you hit it.
I'll have to try Swauger's settings next time and see how I like it. His setup is for later engagement where it will do what I described above. Engage late, but it gives more bottom end once it warms up and you are used to it. Like I said previously it engages like a gun once it gets rolling and through the first turn.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 04-02-2007, 05:23 PM   #7
Team Kamikaze's Avatar
Use a Digital clutch gap and endplay tool you can't go wrong with it.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-02-2007, 05:39 PM   #8
lil-bump's Avatar
Never heard of this tool. I use either my craftmans feeler gauges or my digital verners(calipers)
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-02-2007, 05:42 PM   #9
Pooh2's Avatar
Send a message via MSN to Pooh2
That thing is junk!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 04-02-2007, 05:44 PM   #10
lil-bump's Avatar
Originally Posted by Pooh2
That thing is junk!
What does it look like? Any pics? I'm thinking of picking up the Kyosho all in mechanical gauge.
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-02-2007, 05:46 PM   #11
Pooh2's Avatar
Stay away from the digital tool. The kyosho tool is better.
Old 04-02-2007, 06:04 PM   #12
lil-bump's Avatar
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-02-2007, 06:09 PM   #13
That thing is junk!
because you don't know how to use one you can't say it's junk,
Old 04-02-2007, 06:16 PM   #14
GMartinez's Avatar
Trader Rating: 85 (100%+)
Just in case the kyosho clutch tool # is vzw040 & also works to remove your pinions I use this tool & the caliper when using the caliper each time you measure it the readings are not going to be exact but it will get you in the ball park
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-02-2007, 06:58 PM   #15
bvoltz's Avatar
Here is a link that mite help... http://rctech.net/forum/showthread.php?p=2116982
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 06:38 PM
WTB: Centax clutch for G4S Dave_1 R/C Items: Wanted to Buy 0 06-18-2007 01:09 AM
Centax Clutch Bnw Rookie Zone 1 07-26-2005 03:20 AM
Centax Clutch tkhoo Malaysian R/C Racers 1 02-02-2004 12:09 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
