Old 04-01-2007, 03:16 PM   #1
supermoto552's Avatar
Default Mega ZX12 Rod.
I've just got one of these little engines (second hand) Looks in great condition, but thought i'd take a look inside and whip it apart.
All's fine inside apart from the rod, apparently its had a new rod in 20mins racing ago(new style rod) However on inspection seems to be a little longer, i'm not sure?!
Its seems the brass bushing is a little loose inside the big end of the rod, meaning there is a little slop at top dead center as it slips over...is this normal with Mega engines or other engines brands, i'm relativly new to the sport so not 100% on these things.
When re-assembled the engine seems fine, can't really notice the crank slop as it goes over tdc, just a bit concerned as whether to replace the rod or not.
I fired it up and it runs great on the bench, just not sure the longevity of it if i put it in my car and race it, what dangers are there if i dont put a new rod in?
supermoto552 is offline   Reply With Quote
Old 04-01-2007, 05:32 PM   #2
what dangers are there if i dont put a new rod in?[/QUOTE]
BOOM!
CHANGE THE ROD,MEGAS ARE VERY FAST,BUT YOU NEED TO KEEP AN EYE ON THAT ROD.IF IT POPS YOU WILL DAMAGE THE PISTON/SLEEVE.
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 04-01-2007, 07:45 PM   #3
Ffejdat's Avatar
It is normal to feel a little slop in the big end bushing, like a little "clunk" as you turn the motor over, especially if the motor is dry, no lube. It would however be cheap insurance to replace the rod, you could compare it to the old, and save the old one if it feels like it has the same play.....
Ffejdat is offline   Reply With Quote
Old 04-01-2007, 08:19 PM   #4
Team Kamikaze's Avatar
With the new MEGA T3 Rod which is stronger, it will last a while.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-02-2007, 01:44 PM   #5
Thanks for all the quick replies everyone, i think i'm going to do like Ffejdat said, get a new one for insurance and keep the old one as a spare.
Just taken it to my lhs also, and he said its not that bad, but replace it just to be safe (and he doesn't stock these engines so got nothing to gain) He said i should also be worried about the bushing turning in the big end, its got a little play in it and and move front to back a bit...so just gonna get a new one.
Look at the pic, that aint good surely, the brass bushing being able to be moved front to back out of the rod?!!
Old 04-02-2007, 02:11 PM   #6
rocca30's Avatar
looks like you need a rod,piston,&sleeve. they are none for rod breaking.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 04-02-2007, 02:31 PM   #7
dj apolaro's Avatar
Whats wrong with the piston and sleeve. the black stuff is normal, more than I would like, but its OK.
Rocca30 Call me. or PM me, to see if I can get the trays for the Region 4 race.
Thanks,
DJ Apolaro
dj apolaro is offline   Reply With Quote
Old 04-02-2007, 03:31 PM   #8
Yeah it looks like its been run kinda on the hot side, not really that much carbon, more heat discolouration, don't worry i've cleaned and polished the crank and sleave in the last hour, so both look brand new, and i've polished the top of the piston a bit to remove the carbon, wasn't really that bad at all, perfectly smooth & no pitting, there is plenty of compression left in it, still fairly tight, but i'll get a new sleeve and piston later on, just want to run it properly first.
With regards to that, i see mega do an outlaw 5 port cyl and piston set, am i able to put that in my crankcase or do i need another case?
Old 04-03-2007, 04:06 PM   #9
Do any Mega owners, or other....know if i can put the outlaw 5 port cyl and piston set into my crankcase are they interchangable or do i need to stick with the 3 port that it comes with?
Old 04-03-2007, 05:28 PM   #10
dj apolaro's Avatar
Yes you can, but I feel the 3 port is a stronger motor.
Old 04-04-2007, 05:12 PM   #11
Never had a crank out of an engine before but am i right in thinking there should be an o-ring on the shaft in the grove on the threaded end?? or is it a lube groove, just the crank comes out nice an easy, engine i've had apart in the past the cranks seem hard to push out, this is easy?!
Old 04-04-2007, 07:01 PM   #12
Trader Rating: 4 (83%+)
The black stuff on the piston is great sign i would not polish anything because that creates a coating that helps the life of the piston, i dont understand why people do not like the black stuff on the piston but i love it and i run Mega ZX engines and i have noticed that when they get like that is when they are at its best,just my $0.02..........
Roniel_R is offline   Reply With Quote
Old 04-04-2007, 07:51 PM   #13
trickd122's Avatar
Default piston Varnish
slight varnish build is not a bad thing as Roniel said. However Sligh not excessive, however removing the varnish can open up the cylinder to blow by. I would be careful with cleaning, esp if you think its just a cosmetic issue. Now I would clean the top of the piston and the cylinder head/combustion chamber as you want combustion at it's best. Varnish buildup can never be prevent in combustion as long as oil is present in the process. Now keep in mind that a clean surface disipates heat better than a varnished surface, which can possibly rob the engine of power.
My 2 cents.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 04-04-2007, 07:57 PM   #14
trickd122's Avatar
Default additionally
oh...your fuel mixture has alot to do with the amount of varish accumulated.
More castor more varnish.
Old 04-05-2007, 12:16 AM   #15
Whoops, just read my post...forgot to attach the picture about the groove in the crank.
The engine's all back together now with new rod, and piston top's been polished, did the crank as best i could, didn't wanna go mad as to remove tolerences, and just a gerneral clean up....hope she works well now, just a bit concerened about how easy the crank came out, i took pictures of all components before re-assembly as i'm gonna make a 3d model of it for my portfolio, and saw the grove at the end of the crank shaft??
Mega zx12 offroadnut Nitro On-Road 4 05-27-2008 02:23 PM
MEGA ZX12 MaDaGAS CAR Australia For Sale/Trade 0 03-16-2008 05:45 AM
Mega zx12 help? NitroMaxx3.3 Nitro On-Road 6 12-22-2006 07:16 AM
Mega zx12 race evo1 Australia For Sale/Trade 1 08-28-2006 03:12 AM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
