Old 03-31-2007, 01:38 AM   #1
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Post Pinion gear & Spur size
I wanted to know if I had the right concept about gearing Larger the track smaller the pinion & spur and smaller the track bigger pinion & spur could someone enlighten on this concept if I'm correct or wrong any input is appreciated.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-31-2007, 01:55 AM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
It depends on a few things, but I will simplify so you can decide for yourself
Smaller pinion increases acceleration but will give less top speed
Larger spur gear increases acceleration but will give less to speed
Larger pinion decreases acceleration but gives higher top speed
Smaller spur gear decreases acceleration but gives higher top speed
This is generally speaking as it is possible to overgear your engine.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-31-2007, 03:00 AM   #3
RayJ's Avatar
Pinion & Spur Size play an important role in acceleration and top speed, but the biggest change from the previous generation of cars has been the internal gear ratios. Dropping the internal gear ratios from the 2.50 ranges to 2.00 range has dramatically improved acceleration in our cars. It translates to lower spool up time of the drivetrain to reach the same speed.
RayJ is offline   Reply With Quote
Old 03-31-2007, 12:09 PM   #4
Thumbs up
Thank's for the feedback Scott & Ray j I got a better understanding now much appreciated.
What spur and pinion gear combo TC4?? pacteam07 Electric On-Road 0 05-27-2008 06:13 PM
T2 Spur Gear Size butrflynlambie Electric On-Road 11 10-18-2006 05:25 AM
Spur and Pinion Gear Pitch Nautilian Rookie Zone 1 10-11-2006 10:22 PM
Spur Gear Size Torqer Electric On-Road 10 08-11-2004 05:55 PM
Best spur and pinion gear pitch jedi Electric On-Road 4 06-11-2003 05:55 AM
