Old 04-01-2003, 05:41 AM   #1
MDS
Default Turbo crank in a SX12 RE 3Port Turbo
Hi just wondering could i put a turbo crank in a standard SX12 RE Turbo where it is just a standard crank in it or does there have to be mods the the case, and also could i change the 3 port sleeve for a 5 port or is mods needed for that
thanks
MDS is offline   Reply With Quote
Old 04-01-2003, 11:01 PM   #2
InitialD's Avatar
Default Re: Turbo crank in a SX12 RE 3Port Turbo
thanks
Your crankshaft in your SX12 RE Turbo is most likely the 2146 cranskhaft which does not have a turbo scoop.
If you want to upgrade that, you can get the 2148 crankshaft which has the additional turbo scoop or the 2149 crankshaft which includes a turbo scoop PLUS the fact that it also has a bigger inlet
You can put and exchange out your 3 port sleeve to a 5 port one (2133). Should work straight out. However, if you look at the parts list of a 5 port Novamega engine, you will notice that they include the 5 port and the new 3 port RACE engines with the 2149 turbo crankshaft with the big inlet. I think the 5 port sleeve would be take advantage of the bigger inlet of the crankshaft.
Old 04-02-2003, 04:57 AM   #3
MDS
Default Thanks
So what prices am i looking for, for the crank with big inlet + scoop and the 5 pt sleeve
thanks
also would this increase the performance?
Old 04-02-2003, 08:08 PM   #4
InitialD's Avatar
EURO 89.15
2148
EURO 40.34
2149
EURO 42.61
Prices are from rccarinternational and without tax.
Of course, if you run on a large track, generally there should be some noticeable performance increase. But all this boils down to if you already gotten the right engine settings.
Old 04-03-2003, 12:32 PM   #5
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Question: If you upgrade internal parts with turbo crank and sleeve,goes your motor require n=more fuel adjustment or less fuel?
OVA is offline   Reply With Quote
Old 04-03-2003, 12:33 PM   #6
OVA
OVA's Avatar
Oop one more thing do you get more or less miles per gallon?
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 10:10 AM
Differences between 3port vs 5 port, Turbo vs Non turbo nikkor Onroad Nitro Engine Zone 2 09-28-2005 06:24 PM
Need a turbo head button and turbo crank rcfoolz R/C Items: Wanted to Buy 0 07-14-2005 08:52 PM
FS: MR12 3port with turbo button EuroKRN R/C Items: For Sale/Trade 5 03-07-2004 06:22 PM
Sx12 Re Turbo Convert To M.S User Nitro On-Road 0 02-03-2003 05:22 AM
