Old 03-21-2007, 11:42 AM   #1
Default Car turning right
Hi, I have a fw-05RR and it suddenly started turning right even as the trimming is perfectly ok. Especially on acceleration it almost turns sharply to the right and I have to counter steer for it to go straight. I checked for servo damage but it looks ok. It only does that when it's on engine power. If I just roll it forward it goes straight alright...
Any ideas? ty
deceiver is offline   Reply With Quote
Old 03-21-2007, 11:51 AM   #2
could be seized hub bearings, try to spin each wheel alone
brianhatesnitro is offline   Reply With Quote
Old 03-21-2007, 12:03 PM   #3
Team Kamikaze's Avatar
Any ideas? ty
Did you Check the dogbones/cvd's specially the fronts?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-21-2007, 12:50 PM   #4
I just replaced the front cvd's just to be sure. The bearings feel ok. Tomorrow I will test if it helped.
Old 03-21-2007, 12:51 PM   #5
It could be torque steer, its common on shaft drive cars'
Delta9 is offline   Reply With Quote
Old 03-21-2007, 12:58 PM   #6
rebuild your diffs
make sure all gears mesh
Ghett0 is offline   Reply With Quote
Old 03-21-2007, 01:10 PM   #7
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Given the car a good smack lately into anything? If so you might want to check the suspension geometries.
Shaft Drive is also notorious for torque steer. Clean the car , check the car over. Check all linkages , see if everything is set properly.
Artificial-I is offline   Reply With Quote
Turning Radius bds Nitro Off-Road 7 06-23-2008 10:43 PM
jammin' jpx .28 not turning over???????!!!!! playboy Nitro Off-Road 3 05-08-2008 10:14 PM
problems turning right classic xl Monster Trucks 2 01-01-2006 08:41 AM
help with hyper 7 rtr turning into pro kit??? ocdp182 Electric Off-Road 0 09-04-2005 10:03 PM
Handling when turning right scottyb Nitro On-Road 3 10-03-2002 01:44 PM
