Old 04-27-2003, 10:02 AM   #31
Originally posted by RedScorp
I like to think of engines like firearms rounds. No 2 are exactly alike and all of them have different characteristics, likes and dislikes. No 2 engines will perform at its peak sharing exactly the same settings. But, you can sometimes find a decent middle ground and use that as a base to adjust settings.
You are right about no two are the same. Today, I tried to run the engine again. The engine stall as usual, then this fren of mine at the track helping me to tune the engine. YEs, he got the engine running for a few tanks without it cutting. However, the engine seems to give the 'burbing' noise as if it is getting too much fuel. The expert at the track recommended running a bit lean, but when my fren set it a bit leaner, the engine stall again.
But once my fren reset it to rich setting, the car can run the whole tank without stalling...
for your reference, my climate over here is 30 degree C and very humid.
I'm planning to get another OS TR turbo, for my MTX 3.... The oS tr is generally a very powerful engine once you got it breakin probably. But I feel mind wasn;t done properly....
mave is offline   Reply With Quote
Old 04-27-2003, 02:43 PM   #32
Default It's not the motor it's the pipe....
I had the same problem with that darn AE rear dual chamber pipe. I ditched it for my current set up. Dynamite manifold and an X12 pipe, I also heard good things about the RD Logics 1 piece pipe as well. No more stalling. Some of the guys in the NTC3 forum relocated the pressure line hole by relocating it forward in the chamber with good results. You might want to check that out. I could not get my Novarossi to hold the settings for some reason no matter what I tried. It was just inconsistent but with the new exhaust set up it has been consistent and more responsive if not ballistic at times. The pipe is suspect since you had your friend tune it already, it sounds like he knew what he was doing. A lot of the guys in the NTC3 forum have ditched their AE pipes and switched to other set ups with very good results. I know this is more $ but it would be more of a waste of your $ if you can't get the OS to run to it's full potential. Try a new pipe set up it's cheaper than buying a new motor.
XtremeMDX is offline   Reply With Quote
Old 04-28-2003, 03:06 AM   #33
Send a message via ICQ to V-One S
try pushing your pipe all the way upto the manifold, it works a treat
specially in humid conditions
after a near washout my engine would only run heaps rich, but now the pipe is moved it ran sweet as.
V-One S is offline   Reply With Quote
Old 04-28-2003, 09:50 AM   #34
Default Re: It's not the motor it's the pipe....
I don't mind trying a new pipe, but the problem over here is that there is little thrid parties hop up parts for NTC3. My only way is thru mail order. I'm located in Asia, is there a trusted mail order company that can deliver your kind of pipe?
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
