Old 03-15-2007, 12:32 PM   #1
Default centax 2 clutch help!!!
ok, i have a serpent 960 i just finished building, i have the mega zx21 ds2 race engine and im having a little problem with the clutch, everytime i tighten the thrustbearing screw the gears dont spin freely, ive taken it to my local hobby shop and the guys there cant figure it out, so im lost on this, anyhelp would be appreciated. thanks
nitro08 is offline   Reply With Quote
Old 03-15-2007, 12:36 PM   #2
is their any washers on the shaft to begin with, and the size of the cone that is at the base of your shaft is important too, it may come with the clutch in the kit. Aswell the part that goes on the end of the shaft that the screw goes into, the size of that is important, may come with the clutch, and thats where they tell you to shim accordingly.
Good Luck!
Ghett0 is offline   Reply With Quote
Old 03-15-2007, 01:07 PM   #3
theres no washers on the shaft to begin with and im using the cone that came with the engine
Old 03-15-2007, 01:29 PM   #4
revo523's Avatar
you need to shim the flywheel so it can spin freely.
revo523 is offline   Reply With Quote
Old 03-15-2007, 02:41 PM   #5
First you need to use the cone that comes with your kit (960) not the one that comes with your engine.
Put all the clutch parts on your engine minus the inner bearing. Shim your clutch gap from this point. Take thrust bearing/clutch bell off, replace inner bearing and place enough shims behind so the bell spins freely.
More detailed info on www.cefx.net for more detailed instructions.
Hope that helps.
darkangel is offline   Reply With Quote
Old 03-15-2007, 03:23 PM   #6
flack's Avatar
Starting on Page 23 of the 960 Instruction Manual it tells you in great detail how to install the centax clutch. If you don't have the manual you can download it here:
http://www.serpent.com/product/903000/downloads/
Doug
www.TSRCAR.com
flack is offline   Reply With Quote
Old 03-15-2007, 04:22 PM   #7
Doug
Nitro08, follow the instructions of the manual as Ted is suggesting. If you can't fixe it, please let me know and i'll help you
Paolo
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 03-15-2007, 04:56 PM   #8
yeh i am still having problems with it, i was at the hobby shop today for almost 2 hours while they tried to figure out, neither of my two local hobby shops carry anything serpent. i know the directions in the manual are pretty straight forward but i dunno if i should try shimming the flywheel like others suggested or wut
Old 03-15-2007, 05:10 PM   #9
Nitro,
If you are following exactly the steps of the book, here are the possible problems:
1) too many shims behind the cone
2) cone with too much angle
3) too many shims between the cluch nut and the big clutch bearing
4) too many shims behind the thrust bearing
5) a crankshaft too short (most likely this is not the problem you have)
I think the best option is to call me at the office tomorrow. I will personally talk to you about this. Call at 305-6399665 tomorrow at 3 pm E/T
Paolo
Old 03-15-2007, 05:15 PM   #10
i dont have any shims behind the cone because the directions never called for it and im using the cone that came with the mega engine because i dont recall seeing one in the kit, im going to try a couple more different things and i appreciate the help
Old 03-15-2007, 05:47 PM   #11
and Paolo, im going to be at work at 3 tomorrow and out of town this weekend so i wont have my car with me, but ill try to give you a call maybe tuesday and talk to you about this so i can get it straightened out, thanks man
CENTAX CLUTCH Nikonianmike Nitro On-Road 5 08-31-2008 06:51 PM
Centax Clutch tkhoo Malaysian R/C Racers 1 02-02-2004 12:09 PM
Centax clutch?? NightLife Nitro On-Road 3 07-26-2003 12:08 AM
Who's got a centax clutch? XER987 Nitro On-Road 3 03-22-2003 03:25 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
