Old 03-01-2007, 03:11 PM   #1
KyoshoEvolva03's Avatar
Cool WHY DO ENGINE BEARINGS GO OUT SO QUICK?
Can anybody tell me why the bearings in Nitro .21 engines go out so fast?There should be something that could be done about this?Confused?
KyoshoEvolva03 is offline   Reply With Quote
Old 03-01-2007, 03:22 PM   #2
Trader Rating: 4 (83%+)
I would suggest checking your fuel..
Roniel_R is offline   Reply With Quote
Old 03-01-2007, 03:52 PM   #3
Talking
Good idea.I didn,t know that fuel would have such an effect.What fuel do you recommend?
Old 03-01-2007, 04:12 PM   #4
MassiveMods's Avatar
Bearings need 1 % of the total oil in a fuel to reach their designed life span. Id say you either bought a budget engine or had a faulty bearing.. Which engine was it ?
Engine development manager Rifling Pty Ltd. Nitro fuel designer : Neo + World record title holder 2012 Austalian Nationals 147.6 KPH , 1 st 2 nd and TQ Australian National Buggy titles 2012. Victorian State title 2012 Neo + , South Australian state title ON and Off Road 1/8 2012 Neo + :-) QLD State Titles 2012 1st buggy & trruggy + TQ Neo + MG66 RX7 1st Sportsman Class Truggy QLD State Titles 2012 !! Nitro Addicts Australia . com
MassiveMods is offline   Reply With Quote
Old 03-01-2007, 04:21 PM   #5
Cool
It's a Picco Evo Stock .21 and I'm using O'donnels 30% fuel.I was told the engine was a good one.I have a feeling the fuel was the cause.
Old 03-01-2007, 04:36 PM   #6
Francis M.'s Avatar
Just make sure you run the engine dry or out of fuel and put after run oil after every outing and that should help with the bearing life.
Francis M. is offline   Reply With Quote
Old 03-01-2007, 05:20 PM   #7
BIGTACO's Avatar
Thats odd that the bearings went out that fast. Although I had a .21 Vspec that the bearings went out after like 2 gallons. I guess it just happens sometimes.
RC's: MUGEN MBX5-T Prospec w/Ninja .28!
MUGEN MRX4X w/ Novarossi 321P Tuned
Trex 450 V2
RC Planes
Real Car: 2003 Corvette C5 Z06 Millenium yellow
BIGTACO is offline   Reply With Quote
Old 03-01-2007, 05:21 PM   #8
Mike Ellis's Avatar
Nitro is very corrosive, so running it out and afterrun will help alot as was stated earlier, however rust can still form unless you take the engine apart, clean and oil it. I use 20/50 mobil 1 for this and the motor is serviced after every race weekend.
hope thus helps, Mike
Mike Ellis is offline   Reply With Quote
Old 03-01-2007, 05:25 PM   #9
Trader Rating: 15 (100%+)
How much fuel did you run through it before the problems?
THE DOCTOR is offline   Reply With Quote
Old 03-01-2007, 08:02 PM   #10
Well thats 2 very good products .. Was it the front or rear bearing that went ?
Old 03-01-2007, 08:49 PM   #11
odonnel fuel has gone down in quality I have heard of alot of people switching from it because of that same reason. A fuel that you would probaly find at a normal hobby shop that has a high oil content is byron. I like maxy's but its hard to get in most places
Dan D is offline   Reply With Quote
Old 03-01-2007, 10:06 PM   #12
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Even if ANY fuel's "quality has gone down" proper care of an engine should lead to prolonged bearing life. Francis' post says it all!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-02-2007, 06:41 AM   #13
jag
jag's Avatar
I have used O'Donnell fuel for over 2 years and never had a bearing fail. I believe the problem could be from a lack of maintenance. You should do as Mike said. Nitro absorbs water so if you let it sit in the engine, it will rust the bearings. It could also be a bad bearing.
BTW, I just switched to Werks fuel... not because O'Donnell isn't good (it is) but because Werks is very good.
jag is offline   Reply With Quote
Old 03-02-2007, 12:39 PM   #14
Talking
Thanks to everybody for your advice. I think I know the cause now.The inner bearing seems like it was bad to begin with.After only a gallon and a half the only thing that could have been the problem is the bearing.I maintain the engine really well, always emptying out the fuel and using after run oil after every run. I am thinking of changing fuels though, I've heard Werks is a good brand to go with.
Rear engine bearings OS RG/VG .21 Davidka R/C Items: For Sale/Trade 19 09-27-2011 09:59 PM
What engine bearings hobdog Nitro Off-Road 2 09-11-2008 01:43 PM
NEED SOLD QUICK os V-spec ceramic bearings. micrors4guy R/C Items: For Sale/Trade 11 08-08-2008 09:12 PM
Front engine bearings ??? razzor Onroad Nitro Engine Zone 5 10-04-2006 03:31 AM
Engine Bearings RayJ Nitro On-Road 1 01-11-2004 07:21 AM
