Old 02-26-2007, 06:51 AM   #1
vc05hdt's Avatar
Default 0.8 Module gears
I don't understand how if you have say 5 tooth split with pinion you could have 6 or 7 tooth split with spurs and gears still mesh. I thought rule of thumb if pinions 5 tooth then spurs 5 tooth split???
vc05hdt is offline   Reply With Quote
Old 02-26-2007, 09:58 AM   #2
Trader Rating: 15 (100%+)
I know that the Mugen gears are all the same size in diameter. So a 16 tooth pinion is the same inside and outside diameter as a 19t pinion. This same rule applies to the spur gears. This way any gear split that you want to run will work without a gear mesh problem. Hope this helps.
THE DOCTOR is offline   Reply With Quote
Old 02-26-2007, 03:03 PM   #3
vc05hdt's Avatar
Thanks Doc!
Old 02-26-2007, 03:07 PM   #4
Pattojnr's Avatar
Trader Rating: 19 (100%+)
what they do is slightly change the pitch just enough to keep the spurs the same size. but in doing this i find certain spurs last longer than others. the pitch change is so the size of the spur stays the same as doc noted, but with a tooth count difference. i can show you next time your at the track Mark. biggest diff is my ED pinions. my 16t compared to my 15t, extremely noticable.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 09:19 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 10:10 PM
1/12 front tires, XXL receivers, M8 Module, Crystals, ESC,spur and pinion gears, etc Takt R/C Items: For Sale/Trade 11 12-15-2005 04:56 PM
04 module gears Danpatinod Electric On-Road 4 03-27-2005 03:45 PM
Layshaft Gears, Pinion gears for 1/5 scale.. MaxPower Oval, Larger Scales and More 0 04-08-2003 06:16 PM
