MTX-4 4mm chassis >
MTX-4 4mm chassis
MTX-4 4mm chassis
Old 02-22-2007, 08:04 PM
wario69's Avatar
Default MTX-4 4mm chassis
Which brand of the 4mm chassis does everybody recommend for the MTX-4? I guess mugen's 4mm chassis is the most expensive. The aftermarket ones seems to be considerably cheaper.
-- Wario
wario69 is offline
Old 02-22-2007, 08:37 PM
lil-bump's Avatar
Trader Rating: 85 (100%+)
-- Wario
I once purchased a 3racing ntc3 chassis it was rock solid. the only problem was the holes for the chassis components
where out of place I wound up shimming all 4 a-arms to get rid of the slop. Thats why I like to buy the factory original; the only aftermaket chassis I would buy would be the Kawahara maybe?
lil-bump is offline
Old 02-22-2007, 08:41 PM
Team Kamikaze's Avatar
-- Wario
Don't settle nothing but the original. buy the original 4 mm Mugen chassis it is worth the money.
Team Kamikaze is offline
Old 02-22-2007, 09:14 PM
Boz
Trader Rating: 23 (100%+)
The Mugen 4mm chassis is great and is milled out for the bulkhead to sit lower. Kawahara has a 4mm chassis the same (milled out). 3Racing 4mm chassis is not milled out, so everything sits an extra 1mm high. Nice and stong, just the CG is higher.
Boz is offline
Old 02-23-2007, 07:08 AM
kawahara will be releasing a "multiflex" chassis for the 4. wait for this. all the benefits fo the 3mm chassis with the ability to make it stiff like the 4mm.
it uses onboard chassis stiffeners which you can put in and take out, much like the new xray NT1 chassis will have
TomB is offline
Old 02-23-2007, 07:21 AM
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Since my car is pretty lightweight already (just a few lw option parts). Ive opted for the 4mm 3racing chassis. The price is great , the quality is good and it helps put the weight underneath the car more. Where I then lightened the top of the car via the drivetrain , screws , pivot balls. Which all helps reduce unsprung weight in the suspension and drivetrain. Which helps it perform better.
The only good thing about other high dollar 4mm chassis is there lighter. But with the car already being so light and me having to add weight to it to make it legal. Im sticking with the 3racing chassis for now. If I went with the mugen or kawahara or b-tech chassis. Id have to put more weight on the car and it would all be above the chassis so. I think the route I went with was best , as well the cheapest. The mugen and kawahara chassis alone would have removed my budget for buying the parts that made the chassis lightweight in the first place.
This is also my 2nd 3racing chassis on my 2nd vehicle. Everything is perfect. They bevel the sides for chassis dip , they cut the engine hole to direct wind to the crankcase. Its very solid and stiff. Works for me.
Artificial-I is offline
Old 02-23-2007, 10:27 AM
Trader Rating: 15 (100%+)
I know that the old Kawahara 4mm chassis was not as stiff as a stock Mugen 3mm chassis.
THE DOCTOR is offline
Old 02-23-2007, 01:46 PM
kidDynomite's Avatar
Hey Doc! IMO, the Kawa 4mm is stiffer than stock. Speaking through experience, even the Kawa 3mm is just slightly stiffer than stock.
kidDynomite is offline
Old 02-23-2007, 03:35 PM
I twisted both at the shop and didn't feel the same way. I thought that the stock 3mm Mugen was stiffer. My 2 cents.
