What Really Makes a Car Better?
#16
Originally Posted by dr_catman
It would be good, but it would sill come down to indivdual taste. I think it is best for newbies, such as myself to stick to one good car and practice a lot with it in one good setup.
once this is mastered one can do a drastic change to one apsect of the setup at a time and see how this affects the cars handling.
I'm taking this advice and it's working wonderfully. Before I drive the car I know how the car felt on the stock neutral setup. Thus when something feels better and makes me get faster laps I know which direction to go for how I drive. If I go slower, I can always revert.
I guess the idea is that many people take a setup sheet from a top 10 driver and try to run it and can't go as fast. Then someone is faster and they use their setup and don't go as fast as them either. Point being, they never got used to the car for them and try to go with what feels good or works for someone else. This is ok, but I understand how sometimes one driver may not like the setup someone else TQs with.
#17
Originally Posted by Dredd
Yeah, but that's not how it works
So we're left to pick and choose "hey look what just won x race" and you automatically want that car, engine and setup.
AFM
#18
I actually asked this when I was looking around at some different cars before I decided what i wanted. The answer I got was simple...
"If you can't drive, it won't matter what car you have."
I got a good laugh. I'm assuming the opposite is true. "If you can drive, it shouldn't matter what car you have." Since you can set it up to feel good to you.
#19
So anyway I think that if you give someone a Serpent 720, Mugen MTX-4, Kyosho VOne RRR WCE, Xray NT1, or Team Magic G4s and any available hop-ups (titanium etc) and give them adequate time to get accustiomed to the car and set it up for the track, that they will do well with it. It just takes time.
#20
and have played alot of playstation GT
#21
assuming they have hand eye coordination
The hardest thing for me I think is engine tuning. Hard to get it just right.
#22
What really makes a car better
Here is a perfect example
One of the sponsored racers at the track was running the Khyosho RRR, and runs in the expert class. He is extremely good and fast.
This year he switched, and drives for Serpent and runs both 10 and 1/8 scale.
He is as fast with these cars as he was with the Kyosho.
Like it was said in the ealier post, a good driver can take just about any car, set it uo for his driving, and be just as good as he was before.
#23
#24
hrm...then why do I suck still?
#25
AFM
#26
Originally Posted by Artificial-I
Dont worry about getting it perfect. Just tune it slightly rich if your unsure and make sure its finishing races and getting enough good power. After that you can just focus on the drive. Its much better and then once you get accustomed to the car , then its normally a better time to start tweaking the motor if you think power is holding you back.
#27
I know the basics but when it performs well it idles high and then when I fix idle it has performance issues. I'm just not very good at it yet. I'll get it.
An easy way to tell if your lean or rich on the low end setting is to pinch the fuel line an inch or so away from the carburator and listen to what the engine does in the next few secons. If it wants to die in the first 1-4 seconds or so you are lean. If it keeps idleing for over 7+ seconds then you are rich depending on how long it continues to idle. You should be able to pinch the fuel line and have it idle for about 5-6 seconds before it wants to die.
This method is just to get you close so that you are not adjusting you idle screw to compensate for say a rich mixture that makes your car idle high when you come in the pits. It's idleing high for awhile because it's burning off the extra fuel from the low end setting. After you get it close, then fine tune it with 1/16 or at the most 1/8th turn incriments. Make sure your high speed needle is adjusted properly first before you start tweaking the low end.
I'm not saying this is your problem, but something to consider. After it's tuned properly you should have a snappy punch and return to a normal idle every time. Good luck bro and I hope I didn't confuse you. Engine tuning takes patients when first learning and excperience all around to become effiecent at it. Take your time and ask others for assistance if your stumped. It can happen to even experienced racers. Keep us posted on how things are working out for you on your tuning. Later bro.
#28
Originally Posted by Serpentd
When it idles high, does it stay high or does it slow back down from anywhere between 3 to 15 seconds? If it stays high, it sounds as though your low speed needle is lean. If it idles high and then comes back down it's too rich on the lowend. This can get tricky sometimes.
Anyway I think we can agree that the best car is only as good as the tuning, setup, and driver.
#30
Originally Posted by Rapid Roy
Yup, the most important part of the car is the nut behind the wheel.
