How long do engines last? >
Old 03-20-2003, 11:35 PM
Default How long do engines last?
How many gallons would a engine go through, before buying a new one?
nitrosaurus is offline
Old 03-20-2003, 11:49 PM
me43's Avatar
depends
normally 4-6
but there are plenty factors that will change those numbers
me43 is offline
Old 03-21-2003, 12:39 AM
popsracer's Avatar
ABN (Alum, Brass, Nickle) Piston and Sleeve engines will normally last for about 3 Gallons of fuel if properly maintained.
I personally have an HPI 15FE that is a 1-1/2 years old and probably has 6+ Gallons (of 20%) through it and still runs good.
ABC (Alum, Brass, Chrome) Piston and Sleeves will last at least 50% longer under identical conditions than ABN engines. I am getting an average of 9+ Gallons of 30% through mine.
If you run your engine too Hot (over 260_F) or too Cold (under 220_F) you run the risk of shortening the life of any engine. Proper Tuning and Maintenance is the key to achieving long engine life.
popsracer is offline
Old 03-21-2003, 12:44 AM
me43's Avatar
i belive the "b" in ABC stands for brass not bronze which is a combanation of copper and brass
me43 is offline
Old 03-21-2003, 01:01 AM
Im2lazy's Avatar
My engines have lasted 8-10 gallons, but they are dead. For good performance I'd say they should last around 6 gallons.
Course, I had an engine that lasted around 1 gallon before the conrod exploded and destroyed everything...Needless to say that it was my first nitro engine and I was a little lost as to what to do.
Im2lazy is offline
Old 03-21-2003, 01:11 AM
finchy's Avatar
if you have bad luck like myself the engine could last 2 tanks after run in and the piston and liner get scared by a piece of debris. Not fucking happy. $ 700 dollars down the the drain.
finchy is offline
Old 03-21-2003, 01:34 AM
Im2lazy's Avatar
AU$700? that sucks
Im2lazy is offline
Old 03-21-2003, 07:35 AM
Turbo9000's Avatar
The less ports you have the longer it lasts too.
Turbo9000 is offline
