Old 02-10-2007, 11:00 AM   #1
LOWGEARED's Avatar
Default BREAKIN IN A XXX NT HELP
OK I ve been through 3 tanks in break in with the mach15 engine on my 3rd tank my temps ran a little hot at 250ish or so at 3/4 thrittle it bogged out ... what adjustment needs to be done with the engine!!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 02-10-2007, 11:02 AM   #2
LOWGEARED's Avatar
ANYONE?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-10-2007, 11:08 AM   #3
Serpentd's Avatar
Dude, you need to richen the high speed needle IMMEDIATELY. The big needle screw on the top of the carb. Open it at least 1/4 to 1/2 turns (turn CCW or to the left). You are bogging because of a lean mixture. Not good for a new motor, or any motor for that matter. Get your temps closer to 180-200 for the first 5 tanks. Then start leaning out slowly for the next 3-5 tanks or so and reach a maximum of 230 degrees.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 02-10-2007, 03:56 PM   #4
LOWGEARED's Avatar
Ok from closed I put at Factory settings 3 1/4 turns CCW and LSN at 3 CCW It wont start at factory settings it throws fuel through it like crazy and comes out the exhaust. For the first few tanks it did fine like that, but now seems to flood fast!
I think it might be these cheap C batterys from the dollar store? YOU THINK. I went through 4 batterys in a day!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-10-2007, 04:21 PM   #5
LOWGEARED's Avatar
3 1/4 turns puts me flush with the brass right?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-10-2007, 07:09 PM   #6
LOWGEARED's Avatar
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-10-2007, 08:51 PM   #7
for new engines that are very rich, pinch the fuel line as close as you can get to the carb to get them to fire. after you have finished break in then you can start to lean it out to get it between 200-225 and it should run nice for you and start right up.
davo798 is offline   Reply With Quote
Old 02-10-2007, 08:57 PM   #8
LOWGEARED's Avatar
Man that is the first answer to a ? that has been buggin me all day !!! Yet such a simple answer..
Im gonna have to Idle it a little high at richer settings to right?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-10-2007, 10:25 PM   #9
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Your low-end is probably lean. Richen that. Also wrong forum.
Artificial-I is offline   Reply With Quote
breakin benches spudly12 Nitro Off-Road 11 01-24-2008 07:10 AM
MACH 15 RE breakin help LOWGEARED Onroad Nitro Engine Zone 2 02-11-2007 04:50 PM
O.S. .12tr Breakin raptor 700 Onroad Nitro Engine Zone 2 06-26-2006 05:20 PM
Breakin Period omalley Onroad Nitro Engine Zone 2 10-11-2005 10:20 AM
o.s. engine breakin wlvrn Electric Off-Road 14 09-08-2005 09:56 AM
