-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Sirio S12 TUP PRO Engine (https://www.rctech.net/forum/nitro-road/14870-sirio-s12-tup-pro-engine.html)
hashini 03-16-2003 12:16 PM
Considering this engine for my ntc3. So, does anyone have tried this engine? How about the performance, durability, reliably of the Sirio engine.
Racing4Evo 03-16-2003 07:04 PM
Just finished breaking in one for my friend. It seems like a good engine. I'm not sure if I have the same engine you are talking about. This is a regular 3-port w/ SG shaft. Faster than my TOP (before being modified). Bad things I have heard but not experienced are: 1) Sensitive carb 2) bad connecting rods
JPHRacer 03-16-2003 07:11 PM
Where did you get the motor? If you got in the US then it pobably is just one of the std. motors that trinity imports. If you got it outside of the US then it could be one of the good motors that they make. I cant remember what the designation is but there are two versions that are sold. One is the std motor and the other is a hand mod version. Either way you got a fast motor.
Bounty Hunter 03-17-2003 02:24 PM
Sirio TRP & TRP Pro
Both motors have been availble in the US for quite some time now. I own both. I have not opened my TRP Pro yet but I have gotten some good results with the Standard TRP 3 port. If you guys need any break in tips, plug and fuel suggestions, I would be more than happy to share!
InitialD 03-17-2003 06:08 PM
Re: Sirio TRP & TRP Pro
The TRP PRO 3 port is AAC contruction while the TRP 3 port is the ABC contruction. Have you opened up both to see the differences inside?
Also, what plugs are you using? Standard or turbo? Brand? Hot / cold?
JPHRacer 03-17-2003 09:12 PM
No, the modified one, I think is called AUF or somthing. I know that it is not imported by trinity.
hashini 03-18-2003 06:25 AM
Just bought the Sirio S12 TUP turbo.
Bounty Hunter, appreciate if you can provide me some guide to break in the engine and to maintain it.
Bounty Hunter 03-18-2003 10:24 AM
Re: Re: Sirio TRP & TRP Pro
I believe that the TRP PRO is a Turbo button 5 port not a 3 port
Bounty Hunter 03-18-2003 10:34 AM
Well first off I use Odonnel 30% and RB Plugs. I use a #4 which is a Med Hot plug (different plug manufacturers use different scales). I have found this plug to be equivalent to a Mccoy MC59. The Mccoy however does have a wider temp range that it can handle. Anyways I use a #4 for break in, about 4 tanks idle on the starter box. Just leave the factory settings on the low end the same. Always remember to look for lots of smoke from the pipe, and the pipe should be spitting plenty of oil. After 4 tanks ont he box you now move to the track and do another 4 tanks at the same settings. Remeber to not run at any one given RPM for any extended period of time. Just blip the throttle around the track. After you have done that, I then move to a RB #6 (Med Cold) and start the lean in the top end needle. Remember to only lean in an hour to 2 hours at a time. I would get the engine running to about 220 and run your entire gallon through it. Once your gallon is done then I bump it to race temps (260-270). For the price the motor screams. The only drawback is the time it takes to break the sucker in.
hashini 03-18-2003 11:17 AM
Thanks Hunter. BTW how long did use this engine
Bounty Hunter 03-18-2003 06:30 PM
I am on month 5 with this motor.
Powered By: vBulletin v3.9.3.4
Content © 2001-2011 RCTech.net
