Old 03-16-2003, 11:59 AM   #1
MDS
Default Handling problems on a NTC3
What settings should i use for a NTC3 on a tarmac surface and i am using Sorex 32 Front and back, Type C Firm-Front, Type C Medium-Back? any ideas?
MDS is offline   Reply With Quote
Old 03-16-2003, 01:14 PM   #2
Send a message via AIM to deanspoors
Default help me too please!
hi i also drive in the carpark where MDS drives and i too find my handling bad mainly out of corners! the carpark is quite rough any suggestions!
deanspoors is offline   Reply With Quote
Old 03-16-2003, 11:57 PM   #3
theRED5's Avatar
R/C Tech Charter Subscriber
I don't run rubber tires, but what's the problem?
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 03-17-2003, 12:22 PM   #4
MDS
Default Handling Prob
Hi It is ok going into the corners but it is when i exit them, as soon as i hit the throttle is spins like a donut, any help,
my setting are :
Toe in: Rear 2* Front 0*
Camber: 2* All round
Caster: 90*
Shocks: Quite stiff
Also my car wheel spins off the mark so how could i cut down the wheel spin to gain more acceleration.
Need help?
Old 03-17-2003, 12:50 PM   #5
how do donuts spin?
Old 03-17-2003, 02:43 PM   #6
Run atleast 3 degrees rear toe, and 3 camber up front at 4+ in the back. Also try running reds all the way around with no rear droop (remove the screws) and 4 up front.
Distroey is offline   Reply With Quote
Old 03-17-2003, 02:51 PM   #7
Registered User
Send a message via AIM to bbntc3
Try the diff settings, run the front diff tight to 1/8th turn out, loosen the rear diff to about 1/4 to 1/2 out. Put less droop in the car try maybe -3 to -4 droop, front and rear , 0 droop will give you less traction to the rear of the car.
bbntc3 is offline   Reply With Quote
Old 03-17-2003, 04:01 PM   #8
Francis M.'s Avatar
bbntc3 is spot on with the diff it sounds like your diff settings
is off. adding a rear sway bar will also help
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Tc4 Handling Problems jeffbhhs Electric On-Road 8 12-28-2006 12:13 AM
xxx-nt handling PSiDAWD Electric Off-Road 15 05-03-2006 03:36 PM
Engine Problems on AE NTC3 + ... break-in??? TCRacerPro Nitro On-Road 10 01-12-2006 06:39 PM
2-speed problems, my NTC3 wont shift NitroBoy24 Nitro On-Road 1 02-01-2004 12:50 PM
Help!! NTC3 Problems (Ohio) rotorseth Nitro On-Road 0 01-31-2003 03:32 PM
