0.1 mm shim for Sirio 12 engine
That's a really good question. I can't even find the part number for it.
Originally Posted by straightaway
Where can I buy 0.10 mm shim for sirio 12 engine? Thanks. I only need one. The novarossi 12 shim will not fit.
I use the Serpent shim set, which I think is like the Novarossi shims. I mark the access material on the shim with a sharpy and trim off with sharp scissors. I've done it like this for years on my motors and other racers motors who wanted to go from 20-30%. No probs.
Tim Johnson:
Do you guys carry the Sirio shims at all? If not, could you follow-up on this?
Thanks!
Thanks!
Originally Posted by rmdhawaii
Tommy ~ Great tip! Do you replace all the shims or just put the new one on top?
Rainer, PM me you number. I have a possible business prop that I think you may be interested in.
I have a question..
Sorry if this may sound dumb to some of you and slightly off topic,, but is it ok to add three 0.1mm shims on top of each other?? I currently don't have any 0.2mm shims, so I piled up three 0.1mm shims to have enough clearance to use 30% fuel.
Thanks..
Thanks..
Originally Posted by nitro_moe
I have a question..
Thanks..
Thanks..
Thanks for the reply KidDynomite..
Tim Johnson:
Thanks!
Thanks!
