Old 03-15-2003, 01:06 AM   #1
T-shirt's Avatar
Default RB X-12Rody #215
has any one running this engine yet??
if so any feed back for this engine??
cheers
T-shirt is offline   Reply With Quote
Old 03-15-2003, 01:52 AM   #2
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Re: RB X-12Rody #215
cheers
I have one will tell you tomorrow, just runnig in at the moment
tl2111 is offline   Reply With Quote
Old 03-15-2003, 01:55 AM   #3
Corse-R's Avatar
Have some units of the Rody modifieds (One 215 model - Cinci Worlds model, one 235 - EFRA version - and one 315 - 5 Port Turbo-).
All of them are real good engines, with lots of low-end and very reliable I'll use on racing without problems. I real tough to beat for the rest of engines, you only need to get tune with the powerband of ths engine (slightly different than other and may change your gearing).
Depending your local rules, 215 model should be illegal (keep an eye to this). But if in doubt between 215 w/conical plug head and the 235 model. Get the 215 model, is slightly more powerful.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-25-2003, 01:17 AM   #4
hi guys,
what is the safe setting for the high speed needle for this engine?
how many turns from close?
darthkir is offline   Reply With Quote
Old 03-25-2003, 02:48 AM   #5
mugen_kid's Avatar
its like most motors, depends on day wheather humidity temp sea level etc, but i have novarossi motors and they are the same carb and i run mine flush with outer top with any where to one turn in, depends alot on pipe and plug and fuels.
mugen_kid is offline   Reply With Quote
Old 03-25-2003, 03:01 AM   #6
finchy's Avatar
darthkir go to the RB web site and check out the HSN and LSN settings. They say if you lose the factory presets start HSN at 5 turns out and LSN at 2.5 turn out, idle with a 0.6mm air gap
finchy is offline   Reply With Quote
Old 03-25-2003, 08:30 AM   #7
Trader Rating: 29 (100%+)
Does anyone know where any of these 215 are available? I have been trying to find one.
Eric
Yzlvr is offline   Reply With Quote
