Old 02-05-2007, 03:22 AM   #1
nikoskar's Avatar
Default Differences between silicone oils from different company
Dear All,
Do we know what is the difference between silicone oils from different companies?
Etc.
Kyosho 450 Oil is the same as Serpent 35 or Mugens 30?
If anyone could help me..
Thanks in advance
Nick
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 02-05-2007, 04:44 AM   #2
razzor's Avatar
hope this will help although a bit more info would be welcome.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-05-2007, 06:09 AM   #3
Trader Rating: 15 (100%+)
Pick a company that you can get the oils from and stick with their oils. Everyones are a little differant. Losi's 35w is not the same as Trinity's 35w. Mugen's 500 is not the same as Losi's 50w. If you stick with one companies oils and you want to go a little thicker just go to that companies next weight oil and you will be safe.
THE DOCTOR is offline   Reply With Quote
Old 02-05-2007, 07:33 AM   #4
razzor's Avatar
Thats true to use one make of oils ,I use only GS oils.
Where the hassle is though when you look at setup info from various guys how do you compare and convert that info and put it to use with teh oils you use.The TWF8 link abaove helps but only for certain brands.
the manufacturers dont standardise the ratings.
Casterracing ZX1.5R
Old 02-05-2007, 09:35 AM   #5
Over a year ago someone posted a link for a bunch of companies oils and how they compared to each other. I think that it was on the MTX-3 thread.
Old 02-05-2007, 10:09 AM   #6
nikoskar's Avatar
I only use Kyosho silicone oils.But i just want to know what is the difference between companies because some buggy racers told me that etc 300 kyosho has quicker reaction thans mugen 300 or Lossi 300.
www.rc-world.gr
Old 02-05-2007, 10:59 AM   #7
afm
afm's Avatar
The thickness of the oil is officially rated in Centi Poise "Cps".
Another known and used American rating is WEIGHT "WT".
This WT or W rating is a non world standard and was introduced by Associated and not comparable between brands using this W or WT rating.
Concerning Cps the thinner the oil (fluid) the lower the number, the ticker the oil the higher the number.
For normal shock absorber use, this rate may vary between 100 Cps up to 900 Cps.
For diffs the rate may vary between 1.000 Cps (loose) up to even 500.000 Cps (very, very, stiff).
USA based companies use the "WT" weight rating, where Japanese and European companies use the better linear industry standard Centi Poise rating.
A lot off people think that the ratings between the "WT" and "Cps" ratings are linear but this isn't the case.
You can find the whole story and charts here:
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
AFM
afm is offline   Reply With Quote
Old 02-05-2007, 01:58 PM   #8
nikoskar's Avatar
Thank you very much AFM....
www.rc-world.gr
A new R/C company we can really get get behind! ~McSmooth~ Electric On-Road 37 03-31-2008 02:06 PM
Mixing different viscosity silicone oils? etgdpu Nitro On-Road 5 05-31-2007 01:51 AM
omany oils selling out, diff oils, shock oils, after run oils. pcr2nv R/C Items: For Sale/Trade 7 03-01-2006 08:56 PM
What's better Company Car Clangeddin Electric On-Road 4 09-12-2005 03:54 PM
