Old 01-30-2007, 01:57 PM   #1
Send a message via MSN to srowell3
Default After run oil?
Where does this actaully go? Bit of a noobish question but it isnt in the manual!
Also is this a design fault in the HPI rs4 evo3:
the chassis has a hole for wat seems to cool the gears
but small stones allways flick up into the gears and get stuck!
ive put some tape over the holes and taht should work!
srowell3 is offline   Reply With Quote
Old 01-30-2007, 02:26 PM   #2
Team Kamikaze's Avatar
After Run oil actually goes into the engine it inhibits rust and keep it lubricated internally, after running your RC car you make sure there is no fuel left in the engine ( try firing it up without fuel in the tank,) then take off your glow plug and air filter, drop about 4 to 5 drops of after run oil in it and cycle the flywheel to insure the internal is completely coated.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-30-2007, 03:13 PM   #3
some people say W-40 is just as good as actual "after-run oil" and some people use mavel mystery oil. I haven't tried either of these 2 products during after run maintenance so I cannot comment. I would assume WD-40 would work ok because the lubricants do not evaporate quickly and it drives moisture away from the area contacted which is a good thing. I do not know if it will cause any harm or not so do not take me to sound like I'm advocating it's use.
Dredd is offline   Reply With Quote
Old 01-30-2007, 03:28 PM   #4
gubbs3's Avatar
After run oil is a must for any alcohol burning engine. Everyone has heard rumors as to what you can use as a substitute, Marvel Mystery, automatic tranny fluid, wd-40... and others. WD-40 is not a good choice since it can easily attack the o-rings in the engine and make it more prone to air leaks.
But here's my view: If you spend even just a $100 on an engine, don't cheap out on real after run oil just to save $3!!!
gubbs3 is offline   Reply With Quote
Old 01-30-2007, 03:59 PM   #5
sometime I'd like to know the actual chemicals in after-run oil. I've never seen a listing of what is inside that little bottle.
Old 01-30-2007, 04:00 PM   #6
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
I've been useing marvel mystery oil for the last 8 years with no issues ever since I was working in an emergency room and a ladt came in freaking out because her 4 year old drank a bottle of some red oil her older son left out. long story short the bottle was hobbico after run oil and the MSDS was for marvel mystery oil so since then I've been using MMO still on the same 5$ quart beats 3$+ for a few ounces.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 01-30-2007, 04:04 PM   #7
Trader Rating: 13 (93%+)
ive been using auto tranny fluid for about 4yrs now works fine, i havent seen any rust in the engine and they run strong. o - rings still feel tight
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-30-2007, 05:25 PM   #8
Taylorm's Avatar
-i've also used marvel mystery oil for years. i've never had rust in any of my engines......
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 01-30-2007, 05:27 PM   #9
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I just started using full synthetic 5w10 Mobil Oil. I had a few bearings go bad this past year using after-run oil. I don't run my engines at times up to 5 months at a time, and even with the After-run Oil or MMO, I was still getting surface rust on the crank and with that, I am sure the bearings were doing the same. Since I started using the synthetic (light) oil, I have not had any issues.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 01-30-2007, 06:04 PM   #10
rcabj's Avatar
guys..is there any other name or terms use for this 'mystery oil'
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-30-2007, 06:39 PM   #11
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Good ideal I'm going to try that in my engine.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-30-2007, 07:03 PM   #12
MRX4-R03's Avatar
Are you running engines with the flow ramps"red putty" is so is there any issues using mobile oil with them.
MRX4-R03 is offline   Reply With Quote
Old 01-30-2007, 07:59 PM   #13
RCRjuanabbe's Avatar
How is your glowplug usage? Burning synthetic oil produces a soot more like a carbon build up for lack of a better word.
RCRjuanabbe is offline   Reply With Quote
Old 01-30-2007, 08:17 PM   #14
MRX4-R03's Avatar
Have you thought about using mobil ow20 senti oil because of the soot, and is alot thinner
Old 01-31-2007, 01:27 AM   #15
rcfoolz's Avatar
I hadn't ran into a soot issue with the oil. Also, I hadn't noticed anything with the red putty in my engines either. I've been running the Fantini Max and Mega engines without any problems. I hadn't changed a plug in the Max motor for at least 4 weekends of racing. I do use JP engine polish to clean the engine after every weekend of racing. The engine I have now in the car has about 3 gallons of 30% race blend Sidewinder (10%oil) and it still sticks sometimes getting started.
