Old 01-29-2007, 08:55 PM   #1
Default Can you always hear the car shift?
I noticed something odd...today I was out playing around with my car and my neighbor's car. I clearly heard his car shift...there was a distinct click into gear. On my car I don't hear it. Is it normal for you to not hear the shift all the time? Say if it's shifting late into the RPM range (as I assumed I had set the 2speed on my car). It seems to perform well, acceleration seems good and the top speed is above what you would see if you only got first gear.
Just an odd observation I was curious about.
Dredd is offline   Reply With Quote
Old 01-29-2007, 11:27 PM   #2
Rapid Roy's Avatar
You should hear a noticable drop in RPM's when the car shifts. Sounds like your car is shifting into 2nd gear almost imediatly.
Rapid Roy is offline   Reply With Quote
Old 01-30-2007, 01:29 AM   #3
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
If it shifts early there is a chance you may not here it but if it does it later in the rev's you should usually notice it
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-30-2007, 01:53 AM   #4
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
What Roy said..
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-30-2007, 09:29 AM   #5
Mike Ellis's Avatar
Another thing that will cause that condition is if the clutch is set up tight with slip and the shift shoes are not gapped close to the 2nd gear hub. I have set my car up this way on slick tracks to keep from braking loose at speed. 2 cents, Mike
Mike Ellis is offline   Reply With Quote
Old 01-30-2007, 10:03 AM   #6
Trader Rating: 16 (100%+)
If your car is using the most use "SHOE" type 2-speed, you SHOULD NOT hear the "CLICK" sound like you mentioned.......you should hear the RPM sounds changes just like a real car.........
I know HPI use finger type 2-speed, and THAT might sounds like a "Click" but I have never seen one...
A "dummy" way to tell your 2-speed shift too early or never shift (thats why you cannot hear any differents)....tighten the 2-speed to tight position and check the speed of the car for 1-2 laps the most...you should not hear any RPM differents or shifting...if that is exactly the same as your previous setup, your 2-speed was setup shift too late.
Complete opposite if your car is running 2nd gear immediately...that means you were setup your 2-speed engaged too soon...
Some test and trail, you will get the answer (assumed all your parts are in good condiiton)
Old 01-30-2007, 03:09 PM   #7
My Neighbor was using an HPI so maybe that's why there was a noticable sort of click or whatnot.
Now I ran my car today with no other noises and listened closely. There is a point where I can hear the RPMs change and the engine sound changes ever so slightly then continues on. So it is shifting, I just wasn't actually hearing anything without really listening for it.
Was just curious.
Old 01-30-2007, 03:23 PM   #8
bvoltz's Avatar
Trader Rating: 44 (100%+)
General rule... it should shift about 40 feet off the coner... but like I said, this is a general rule, the track, engine, etc... will change this to get the max out of the setup for a fast lap time...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 01-30-2007, 06:46 PM   #9
Bob Malphurs's Avatar
A good way to tell if your car is shifting is to hold it by the roll bar off the ground with the car running, ease the throttle open and watch the front of the car. When it shifts the front end will pick-up. Once you have the car shifting right on the track you can use this method to get a good reference point for the shift after a re-build!
Bob Malphurs is offline   Reply With Quote
Old 01-31-2007, 09:08 AM   #10
teammpp's Avatar
An easier way to adjust the gearbox is to have it change at approx. the 1/3rd point of the main straight. Hours of testing showed that this give us the fastest time between 2 points at either end of the main straight and our lap times tumbled in general
teammpp is offline   Reply With Quote
Old 01-31-2007, 02:19 PM   #11
bvoltz's Avatar
Good point, the track I run at, 40 feet is about 1/3... Also if you slip your clutch /or don't, this will have an impact on the shift point.. Depending on the motor, I basicly want to keep the engine in the power band as long as possible...
Old 02-03-2007, 06:41 AM   #12
RAT-BOI's Avatar
Default no not al ways
depends on how you have it set up to change
TEAM ASSOCIATED FT TC5
SPEED PASSION
MUCH MORE
ATLAS BATTERIES
TWISTER HOBBIES
RAT-BOI is offline   Reply With Quote
need masks come hear tuner_taz Painting, Designs, Graphics and Photography 5 01-03-2007 06:47 AM
What do you hear teammidget lilB Florida Racing 25 06-22-2006 04:15 PM
Story you have to hear to believe brc358 Buyer/Seller dispute and Feedback discussion forum 0 06-12-2006 03:16 PM
Question about - shift and + shift mojoman Rookie Zone 2 02-13-2006 05:51 AM
Hear Say Nipple Singapore R/C Racers 16 03-25-2005 12:37 AM
