Sanwa ERG-WRX
Sanwa ERG-WRX
Has anybody tried it?
Planning to use it in my 720, which connector is it supplied with? Is it the old sanwa style or a futaba compatible one?
By the way, would you guys buy the Futaba Fasst system or the Spectrum DSM HRS, for use with a 3pk super?
Thanks a lot...
Thanks a lot...
While I'm at it:
Does anybody have the dimensions of the SR3000HRS (spektrum receiver)?
MartinG:
I use the same servos on my 720 also and they are great,the WRX is a digital servo and its the fastesat servo on the market today....
The WRX is fantastic servo and very reliable. The plug is the new style. I could say Futaba compatible but it does not have the small "blade" on the side of the plug. That means that it can fit into a Futaba receiver, while a Futaba servo does not fit into a Sanwa receiver unless you "shave" the plug.
Regarding the size of the spektrum receiver, I do not have the exact dimensions however, it is the same size with the Sanwa RX 211 receiver, which is a very small receiver.
//BR
//BR
Thanks a lot, the WRX seems lika a good bet then..
So what do you think:
Futaba FASST vs. Spectrum DSM HRS, pros and cons?
the other car driver was more lucky. The problem started when he was at a slow part of the track and the fail safe activated and the car stopped with no damage at all a few meters further down.
Since then I switched back to the original module and receiver and I use crystals. I managed to find a crystal set that is really difficult to find and it is not spread around.
I believe that this technology is not mature yet and it is possible that it can be affected by factors that we and the manufacturers do not know them yet, in order to eliminate them.
As for the Futaba versus Spektrum, I do not have an opinion since I have not tested Futaba.
//BR
Regarding Spektrum,, I'm currently using the DSM PRO version and I can say it was a bit confusing using a short antenna at first. The failsafe kept self-activating at certain parts of the track . But ever since I extended the reciever antenna to full extension (roughly 5 inches), I never had a problem. Besides, both Spektrum and Futaba FASST use the same 2.4ghz technology.
Good luck..
Thanks for your input guys, I guess I'll just have to order a WRX then...
nitro_moe: Do you use a WRX for th/br? Isn't that just overkill? Wouldn't it be better to use a light, but equally fast servo primarily designed for helis? Is torque really that important for th/br?
etgdpu: Sorry to hear about your crash, It stinks when you have to put your hard-earned cash into repairing your ride. Sadly, that's what all hobbies are about; making your wallet lighter...
Sanwa ERG-RZ
Sanwa ERG-VR
Regarding steering,, I'm very happy with the speed and torque of the WRX. Sometimes you need to have a small margin for steering corrections and the WRX is one of fastest operating servos currently in the market. So it should be highly responsive when you need to make a correction. If you feel it's too fast for you, you can always mess around with the servo delay in your radio.
Trust me,,, you will be amazed by the speed and performance of these servos
