Old 08-23-2007, 04:32 AM   #106
itchy b's Avatar
Originally Posted by cdelong View Post
Don't have a MTX-4, so you got me there. I was talking about the "real" cars
So were we!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-23-2007, 08:01 AM   #107
Corse-R's Avatar
...and someone mentioned Mugen has two bearings on the inside?? wrong. I've setup Mugen, Serpent and Kyosho clutches exactly the way I described..... the method works on all of them.
Calipers don't cut it here guy's..... you need a clutch gapping tool
Pssst! the one clutch from Mugen that comes with two bearings 'in' is the MTX4... Oooopns! just read now that someone pointed you on what clutch had two bearings 'in'.
Calipers? Yes... surely! clutch gaping tool? well, I have one and ever forget to carry it. Has much more service a set of metal gauges like the ones you use for gaping electrodes on your spark plugs. Maybe is 'less cool' but... makes their services.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-23-2007, 08:45 AM   #108
razzor's Avatar
Thats actually a good idea to use a automotive feeler gauge.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-23-2007, 09:23 AM   #109
esham's Avatar
Originally Posted by razzor View Post
To add to the subject i have been using this method suggested by dennis Richey for setting up the clutch on the G4S.
I would think it applies to other centax clutches as well as they are the same in principle.
http://www.kfactoryracing.com/expert...24130345-74975
Thanks for sharing guys..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-30-2007, 09:03 AM   #110
ScudMan's Avatar
Default What Color Clutch Shoes are you guys Running???
Hey guys. First, big thanks to all the FBF guys for being so cool -- Thanks for making entry into 8th on-road alot easier and less painful...
I'm trying to figure this whole clutch thing out - I've been using a combination of yellow and or grey (black) shoes- the blacks seem to last a little longer and stay consistent longer.
1) How many tanks of fuel do you guys get before having to re-setup your clutch??
2) While this article has been great, I still am not clear on "rotating" shims around -- so let me re-state my question like this:
Q: You have your clutch setup right, and the car is running good. You drive through about 6 or 8 tanks, and now you maybe start to hear some slippage on the back straight - so it's clearly time to readjust - (Hopefully everyone is on the same page here) --> Do you back off the clutch nut? Do you TIGHTEN the clutch nut?? Do you DO NOTHING with the nut, but instead MOVE SHIMS AROUND??
This is what I'm trying to figure out.
For the record, starting with a new shoe, I usually have 4 shims UNDER the bell (Closer to engine), and then 2 shims OUTSIDE the bell (closer to side of car) With a gap somewhere in the realm of .6 or .7 or so.
I'm sorry if alot of these questions are addressed in Mike's article, but if they are, I guess I just don't "get it" good enough yet. Thanks again guys.
-scud
ScudMan is offline   Reply With Quote
Old 08-30-2007, 01:41 PM   #111
SlamMan's Avatar
As your clutch gap is growing from wear, from .5 to .7 for example, you would then move .2 shims from under the bell to outside the bell. This reduces your clutch gap back to .5 and retains the same end play.
SlamMan is offline   Reply With Quote
Old 05-27-2008, 12:33 AM   #112
Roger's Avatar
top
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 05-30-2008, 08:14 AM   #113
mcsquish's Avatar
Is there a copy of the article out on the Internet anywhere? I tried the link from post #50 and tried finding it on the Extreme site plus did a google on "Mike Swauger extreme clutch". Figures I miss a month and there's something good in it.............
mcsquish is offline   Reply With Quote
Old 05-30-2008, 10:24 AM   #114
yeah, i too would like to see a complete build of the clutch.
Baedarlboo is offline   Reply With Quote
Old 05-30-2008, 12:18 PM   #115
quietstorm76's Avatar
Check the new Mugen only forum. Someone posted a link to it.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-30-2008, 12:41 PM   #116
ESWLFSE's Avatar
Send a message via Yahoo to ESWLFSE
What you are compensating for when you make an adjustment is clutch shoe wear. If you started with a .6 clutch gap and find that you are at .8 due to wear you will need to remove .2 behind the rear bearing to get your gap back to .6.
Assuming everything was shimmed properly at the beginning that same .2 will now need to be added in front of the clutch to maintain your thrust bearing clearance.
This is why you can simply move the correct size shim from the back to the front.
ESWLFSE is offline   Reply With Quote
Old 05-30-2008, 01:34 PM   #117
that link bring you back here....lol
Old 05-30-2008, 01:39 PM   #118
Suspended
try this it's pretty good
http://www.cefx.net/tips/nitro/clutch/index.php
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 05-30-2008, 02:52 PM   #119
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Have been using Glenn's method for years.
http://www.serpent.com/news/10534/Bu...-Clutches.html
Tire Chunker is offline   Reply With Quote
Setting up the Centax Clutch the righ way! BeBop Nitro On-Road 18 05-08-2008 04:52 PM
Setting up a centax 3 clutch SMOKESHOW86 Nitro On-Road 5 07-29-2007 07:23 AM
Good article on installing clutch shoes Cain Monster Trucks 3 08-27-2006 07:39 PM
Ball Diff & Centax III Setting Serpent D Nitro On-Road 2 03-18-2004 03:38 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
