Old 01-17-2007, 09:01 PM   #1
Default can't decide... 1/8 or 1/10
Well, I have a decision to make. I cannot decide if I want to go 1/8 or 1/10 scale for my main car. Basically it's between the Team Magic G4S RTR and the Power Racing XR/80 RTR. Reason I am going to get an RTR to begin with is I want to learn the car and not have expensive carbon parts to break as I learn. I can buy new and better upgrades as needed.
Anyhow...I have a TM G4S RTR and like it. I always thought 1/8 was too expensive to get into. Then I saw the XR/80 RTR and it's pretty damn cheap for a 1/8 scale. So that got me thinking...should I move up to 1/8 or stick with 1/10
quite a choice to make. So here's the brunt of my question. Is there anything I should know about 1/8 scale that is a big change from 1/10 and I should think about first?
Dredd is offline   Reply With Quote
Old 01-17-2007, 09:07 PM   #2
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Tires would be the biggest change. Racing 1/8th pretty much will "require" a tire truer and quite a few set of foam tires.
Dan is offline   Reply With Quote
Old 01-17-2007, 09:16 PM   #3
for 1/10 I can go buy tires from like GRP, Jaco and the like. Can you not do this for 1/8? Or do you mean that the quality is better for 1/8 if you mount and true your own?
Old 01-17-2007, 10:41 PM   #4
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Depends on your budget are you willing to spend more on everything ?considering 1/8 scale can be more expensive to keep up than a 1/10 scale I like 1/8 scale but I'm not ready to spend the money right now I'm having a lot of fun with my 1/10 scale right now but later down the road i will be purchasing a 1/8 scale kit also I like building my own kit much more satisfaction when racing it.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-17-2007, 10:47 PM   #5
That's interesting...so replacement parts are more expensive for a 1/8 scale car?
If so I'll stick with 1/10. That's good to know.
Old 01-17-2007, 11:41 PM   #6
Default 1/8 Nitro
I have both, and think 1/8th is similar in cost. You can get a full set of rubber for $32-$36 bucks, and you can run them for a weekend or 2 depending on the surface and the amount of practice you get. If you have never tried one, do so before making plans. You can get a great deal on a lightly used MRX-3 chassis, parts are reasonable and available, and they are extremely durable (handle excellent). Once you try 1/8th, you will be hooked! Even if you only race it once every 2 or 3 months, far more fun-factor than any other on-road option. There is no substitute for 1/8 on-road.
onthegas is offline   Reply With Quote
Old 01-18-2007, 03:44 PM   #7
There's 2 things keeping me from jumping right to 1/8. With 1/10 you can get much more varied selection of bodies, although they aren't as aerodynamic as the Lola style bodies I see people run with 1/8. Also that a 1/8 needs a little more room to run in which may be asking too much where I'm at.
Keep the info and suggestions coming. I'm willing to listen to everything and everyone.
Old 01-18-2007, 04:13 PM   #8
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Go with where you have a good amount of races and tracks to run on. Most likely a 1/10th but some have the option of both.
If your bs'ing around p-lots just get something simple.
Artificial-I is offline   Reply With Quote
Old 01-18-2007, 04:21 PM   #9
I do plan to get into some racing, but around here I don't see much for 1/8 size. There's a track not far, but it's really not that large. At least it's not as large as some tracks I've seen that host stare/national events. I may just stick with 1/10 since I don't really have to buy anything specific right now.
Although something about the larger scale and higher speeds makes it hard to choose.
Old 01-18-2007, 04:41 PM   #10
mugendude's Avatar
get tenth to get started but eighth is much funner but to have fun you must pay the price 1/8th scale is really pricy
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 01-18-2007, 04:54 PM   #11
I have a Team Magic G4S RTR now which is my main car. I became interested in 1/8 after seeing the XR/80 RTR which is very cheap to get into 1/8. However, since I have the TM now it's probably better to get some upgrades for that (engine, UFO Clutch etc).
Thanks for all the advice and whatnot.
Old 01-18-2007, 05:10 PM   #12
Moderator
Just keep the g4s. If anything get an off-road truck or truggy or buggy , thats the best bet. Youll get to see how much more areas you can run , virtually anything. As well itll show you what the hobby is about on the off-road side. Will also open up new tracks that might be available to you. Racing on an off-road track is much more fun , just like racing on an on-road track vs bashing around.
Id look for a used vehicle on ebay or something , theres a ton of people parting with them so the initial cost is gone. Use a good eye and you can normally find barely used ones with the needed modifications already done.
Old 01-18-2007, 07:29 PM   #13
get both
civiceg is offline   Reply With Quote
Old 01-19-2007, 12:16 AM   #14
Originally Posted by civiceg
get both
If only it were so easy...
Old 01-19-2007, 04:56 AM   #15
Trader Rating: 18 (100%+)
Default 1/8 or 10th
I do have both scales, 10th and 1/8.
I have a couple of Kyosho RRRs, and some Mugens.
In 1/8 scale I have an Evolva, and also a PRP XR8
Even though the XR8 is not quite up to par as the Evolva, when set-up right, the car handles great. I actually have more tme in driving the XR8 than I do my Evolva. Parts for the PRP cars, XR8, and the RTR XR80 are very cheap, and very durable. For practice, I buy off-name brands and only pay around $18,00 for a full set at the track. But for racing, you would want a couple of good sets. These cars use the Serpent style wheel. A good set of tires will run somewhere around $32.00 and up for a full set.I would have to say that parts for the XR8 run around a little more than 1/2 of what the Kyosho parts run. Check out e-bay or even some other sites, and you will probably find used Evolvas, Mugens, Serpents and PRP in both 10th and 1/8 scale at a fraction of the cost of new ones.Dont let the "high" cost of 1/8 scale stop you, as there are choices in both used or in the case of PRP new cars to be had. Once you try 1/8 scale, you will find it is a whole different world.
brc358 is offline   Reply With Quote
Please help my son decide... glock19er Monster Trucks 16 08-22-2007 07:23 PM
Help me decide natskiboy Electric On-Road 13 01-06-2006 09:49 PM
need help can't decide what to buy next classic xl Monster Trucks 6 08-13-2005 01:46 PM
help me decide! kh15 Electric Off-Road 15 01-05-2005 12:13 PM
Help me decide what to get...... RoadRat Electric On-Road 4 05-18-2003 05:55 PM
