Need help identifing this serpent model
Need help finding out what model of serpent this is?
That looks like a '98 model 235mm (1/10th scale) 4wd w/graphite radio tray!
I am trying to find out which model this is so i can locate owners manual and parts list.
That is the Serpent Impact. I still have one myself. Not too sure if you can find info out on this bad boy or not on the Serpent site. Good luck. I will try and help answer questions if you have any since I use to race this car weekly years back. It was a VERY fun car to drive!!!!!
Originally Posted by RedRC
Bob is right on the money. It is the Serpent Impact MK2 235mm chassis in 4wd spec. Im not 100% sure about the MK2 but its definitely not the M2 which came later and it definitely not the original Impact.
that is a beat up serpent Impact, but not a original spec 98 model. the 98 came with the old purple aluminum shocks; the servo mount was not stock; and the rear body mount was attached only at the rear of the rear arms, not in the front and rear like the one in the photo. Whoever owned this car added the newer parts. The radio tray is 98.
parts should be very easy to find for this car
i miss the 235 class...
