Old 02-03-2007, 12:27 PM   #61
fullout's Avatar
Send a message via MSN to fullout
i was just curious if anyone out there was snapping the dog bone from the 2speed to the rear diff. i put a o.s. 18cv-r into rs4 3 evo and ever since then i've been snapping that one dog bone almost after every tank. i think its weird because i use drift tires on my car so there shouldn't really be to much force on it. and the dog bone from the 2speed to the front diff is still the original. i'm stumped
fullout is offline   Reply With Quote
Old 02-03-2007, 08:00 PM   #62
ok, screw it, ima get a starter box....hows this?
http://www2.towerhobbies.com/cgi-bin...?&I=LXHUD0&P=0
also, i dont think it comes with a charger, so what would i do bout that?
SpeedDemon911 is offline   Reply With Quote
Old 02-03-2007, 09:38 PM   #63
Rapid Roy's Avatar
It doesn't come with a battery either. Get a 12 volt gel cell battery and a wall charger.
Rapid Roy is offline   Reply With Quote
Old 02-03-2007, 09:47 PM   #64
it says it does. anywho, ima get the one that doesnt come with the battery, but its the same thing, since i already have a 12v and a charger for it. so, is that a good starter box for the ss?
Old 04-07-2007, 04:54 PM   #65
grrr! ok, issues again. it was running to well, and since my bearing broke, i havnt started it...i got it started today for like 10 seconds, but halfway up the throttle, it stalled. the settings were low-1, high-3, 1.5mm throttle. i am using White Lightning 20% nitro fuel...my engine can take 30% nitro. could my problems be because my fuel is like, 1 1/2+ years old? lol. this is just really pissing me off tho...i didnt change any settings, and it wont start anymore!
Old 04-07-2007, 10:18 PM   #66
check glow plug, try newer fuel, richen up the low end needle a little bit.
That's the things I would look at first starting with richening up the low end. 1 turn out from closed is pretty lean.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 04-07-2007, 10:33 PM   #67
so ur sayin try 1 1/2 - 2 turns out?
Old 04-08-2007, 07:26 AM   #68
Yes. Most people run a little rich on the low end for easy starts and so you get a smoother idle without stalling.
Old 04-08-2007, 11:21 AM   #69
so...
low-2
high-3
idle-1.5-2mm
thats good right?
Old 04-08-2007, 11:26 AM   #70
so...
low-2
high-3
idle-1.5-2mm
thats good right?
See what happens
Old 04-08-2007, 11:45 AM   #71
will do...also, to lighten the flywheel...is it bad to take the stock flywheel and drill 2-4 holes in it...maybe 1-2 mm in diameter?
Old 04-08-2007, 12:12 PM   #72
There's no optional flywheel? I think the holes would throw the balance off.
Old 04-08-2007, 12:50 PM   #73
ok, and there ar 2 optional ones, but im cheap, and broke
Old 04-08-2007, 12:59 PM   #74
aren't we all
Old 04-08-2007, 02:16 PM   #75
well i did just order $100 worth of stuf for the car.....
anyways, i can get it started, but the starting rod, or w/e u wana call the thing that the one way bearing goes one, broke, it broke cause of how i was starting the car with it...i used a dremel and turned it into a philips screw head...lol, i do have another one tho, and i just put it in, now i just have to wait for my stuf to arrive around the 14th-17th its supposed to be i think. anyways, ima finally be able to start the car with my rotostart, i ordered a new charger
LOOKING TO BUY RC NITRO TRUCKS, CARS, BUGGYS, ELECTRIC OR NITRO CASH IN HAND jd267 R/C Items: Wanted to Buy 26 09-06-2008 12:25 PM
WTTF: mini electric or nitro (nitro perfered) and also looking at all nitro deals.... xxx-ntad2 racer R/C Items: Wanted to Buy 3 04-25-2007 07:53 PM
XM Ready radio and Nitro Buggy to trade for Nitro Rustler or Jato RTR NewNitro R/C Items: For Sale/Trade 1 03-17-2007 11:38 PM
FS/FT Tmaxx, Nitro Rustler, Nitro RS4 Racer, Nitro RS4 RTR, Losi XXXNT RTR ChrisR40 R/C Items: For Sale/Trade 24 03-20-2006 03:47 PM
FOR SALE:Nitro 4tec, Hopped Nitro Rustler, Parts lot, Picco .12 engine, plus more!!!! feel my impact R/C Items: For Sale/Trade 0 08-05-2002 10:41 PM
