Old 03-18-2003, 05:59 AM   #76
Sydewynder, what clutch are you using? Also which engine mounts? (because I'm not ready to give 50$ for adjustable ones) Is your Super heavily hopped up to survive the power of the Novarossi Big block?
Speed De is offline   Reply With Quote
Old 03-18-2003, 06:11 AM   #77
Old 03-18-2003, 02:52 PM   #78
I'm using an MIP/HPI racing clutch. The mounts I got are WolfPack but Ofna sells an adjustble mount that's more adjustable than the WolfPack and cheaper.
I'm running:
HPI super SuperNitro chassis
HPI graphite upper deck
Cross Al upper arms
Cross Al bulkheads
Cross Al midblock
MIP shiny CVDs
HPI hardened outdrives
Robinson Al small pulleys
Ofna 2 speed
CRC Al steering
Kyosho metal disc brake with Robinson pads
Some other stuff I don't remember offhand
The pieces that get worn out fastest are the outdrives. Get the longer silver Rush ones. The so called hardened ones seem like the same soft metal just plated.
I have twisted dogbones before. They're straight but if you look at the pins at the ends of the bone, they don't line up like when new.
Sydewynder is offline   Reply With Quote
Old 03-18-2003, 05:55 PM   #79
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Any other FW04 owners besides Syde, psycho, and me?
Oh yeah....they're right too. My FW04 is a pig in the corners but the car is very easy to drive.
Dan is offline   Reply With Quote
Old 03-18-2003, 06:48 PM   #80
psycho's Avatar
Dan
Yeah, where did everyone go? I guess everyone is racing foam sedan class this year.
psycho is offline   Reply With Quote
Old 03-18-2003, 11:08 PM   #81
Dan
Dan's Avatar
Originally posted by psycho
Dan
Not sure, hope the Super10 class doesn't get killed off like the 1/10th .15 Class. I last raced the FW04 at the November RCCAR race. Check it out, I'm in the results. Did terrible but not bad for running 2WD...
Old 03-18-2003, 11:13 PM   #82
popsracer's Avatar
Default FW04 is a pig in the corners
Why do you Guys say this? With a fully adjustable suspension and F/R toe, you should be able to dial in/out anything you like.
A little less Rear toe and a little Front Toe-out should help make it more nimble.
popsracer is offline   Reply With Quote
Old 03-18-2003, 11:31 PM   #83
Dan
Dan's Avatar
Believe me, tried it all. I'm running a much stiffer rear end and changed my caster settings now to get some more steering and induce oversteer. It still is not as repsonsive as I like (maybe because I'm used to my onroad with oneway) and I could use more steering.
I mainly think its the overall weight and more unsprung weight on each of the 4 corners of the FW04 which causes its handling characteristics.
Old 03-19-2003, 03:59 PM   #84
I got the FW04 to handle pretty decent now. Running less rear toe, stiffer springs in the back, swaybar in the back only, smallest degree of front caster, and less rear droop.
Pops:
The car always seem to have the rear really planted so it feels like there's not enough front bite and steering. Turn in and transitions feel slower than my Supernitro because of the weight. The car is fun to drive since I have a 4 stroke in it.
You are right that we should be able to free up the rear for more steering. I guess for me I just haven't been spending enough time to play with it. Racing 1/10 electric, 1/10 gas touring foam + messing with 1/8 buggy, 1/10 onroad etc. just doesn't leave much time to try things out.
Dan:
Alot of people decided to go 1/10 gas foam only this year. A local by the name of Chris A is running a super now so + 1 for super size, - 10 for those that left.
Old 03-19-2003, 05:15 PM   #85
Dan
Dan's Avatar
Syde, some of the guys on the other FW04 forum are saying OS is releasing a new .30 4 stroke. Not sure how reliable the sources are. Anyways, I think I need new valve springs for my engine.
Probably need to swap engines for that Fremont track too.
Old 03-19-2003, 08:21 PM   #86
popsracer's Avatar
Originally posted by Sydewynder
[B]I
Dan:[B]
Man do I know what your talking about. Way too many Cars to work on.
I did get my Foam tires and Donuts for the Super today. Hopefully I can find the time to get the Super set-up before Sunday, to try them out.
Steven (popsracer)
Old 03-20-2003, 10:40 PM   #87
popsracer's Avatar
Default Super set-up
Guys;
Mounted my new Foams on the Super today and the Wide Rears rub the Header on the left side. Time for some gentle re-bending AGAIN.
I'm going to put 40wt oil Front and 35wt oil Rear and try some different spring combinations Starting with Green/Black. Am also going to increase the Droop F & R by a few mm's. I used to race the Cars on High Traction Asphalt, but the track is no more, so I'm stuck with LOW traction surfaces.
Old 03-23-2003, 09:10 PM   #88
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
ttt
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-30-2003, 09:32 AM   #89
hey popsracer hows that fantom 15 working with the foams on.
laro is offline   Reply With Quote
Old 04-07-2003, 06:49 AM   #90
TimPotter's Avatar
Yeah Pops... how do you like the Foams ?
[SIZE=7]M11,M8,SPEKTRUM AND MORE[/SIZE][COLOR=Black] gonzo416 R/C Items: For Sale/Trade 0 10-12-2005 07:50 PM
Associated RC18T super 370 size N4S R/C Items: For Sale/Trade 17 08-05-2005 04:17 AM
Car Discussion: Which One Is The Best ? darthkir Nitro On-Road 34 01-27-2003 03:17 PM
