Old 05-19-2003, 04:50 PM   #151
hey guys i ran my super this weekend and it was quite impressed. Changes i made were
- 1 degree camber all around
- i am using the proline super foams (wide in the back and narrow front)
- 5mm ride height in the back and 3mm in the front.
- 0 toe in the front
i still get a bit of over steer around the corners but they are alot more controllable and no spinouts going full throttle with a .21 in a straight. only thing is that my chassis is going to get eaten pretty quick riding that low. i'll experiment lifting the front a little. very impressed so far, wasnt lagging too much behind an impact. i think i will try the diff spring kit next.
compuatic is offline   Reply With Quote
Old 05-20-2003, 10:24 AM   #152
popsracer's Avatar
Default Centax Clutches on Super's
Guy;
Several major concerns to consider:
1) The Flywheel needs to be the correct diameter and match the Motor Mounts for starter box access.
2) The Engine/Gear spacing needs to match the HPI Spur Gears and this may require different Motor Mounts.
popsracer is offline   Reply With Quote
Old 05-20-2003, 12:30 PM   #153
Number 11's Avatar
Cool, glad those changes worked for you. The Super doesn't do well with a lot of camber.
I didn't get to finish my race as soon as the race started there was a pile up I tried to work my way through it but got tee boned trying to get around the pile up. My servo arm broke and I probably could have fixed it but decided to bag it. I had the car dialed in it was disappointing.
Number 11 is offline   Reply With Quote
Old 05-20-2003, 12:36 PM   #154
BOWTIE1's Avatar
Send a message via AIM to BOWTIE1 Send a message via Yahoo to BOWTIE1
hi yall i just got a hpi super nitro rs4 anythind i need to do befor running it ??? i am new to on-road i race off road all the time thanks
BOWTIE1 is offline   Reply With Quote
Old 05-20-2003, 12:44 PM   #155
Number 11's Avatar
I would look through the post and use some of the setup's. There is nothing in paticular that you will need to do besides breaking in your engine if it is new. Also get the 7512 BMW V12 LMR body I wouldn't waste my time with anything else. Save your money and use it on other parts.
Old 05-20-2003, 04:12 PM   #156
BOWTIE1's Avatar
Number 11 ok well it is uesd and been convereted to a 21 car and had skyline body on it now here ia a pic of it
Old 05-22-2003, 11:21 AM   #157
Default Racing clutch
Hey do you guys have the racing clutch? I bought it yesterday and found that it has a conical shape Is that normal because I don't know how will it grip the bell. Need help!
Speed De is offline   Reply With Quote
Old 05-22-2003, 07:15 PM   #158
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Which racing clutch did you get? If its the HPI one, it will work fine. Just follow the instructions.
Dan is offline   Reply With Quote
Old 05-22-2003, 10:55 PM   #159
Yes it is the HPI clutch but thre weren't any instructions in the bag so what should I do. Why does it have a conical shape
Old 05-22-2003, 11:21 PM   #160
popsracer's Avatar
Default HPI racing clutch
Speed De;
Check out HPI and MIP's websites about setting up the clutch (there exactly the same clutch), there should be some information on one of the sites.
The conical shape is to reduce the shoe contact area. The racing clutch grabs better and does not need as much contact with the inside of the clutchbell to work.
I usually run mine in the middle hole, but some slight trimming is nesessary and you should have the instructions in front of you before cutting.
Old 05-23-2003, 04:03 AM   #161
Should the shoes be joined together when they are put on the flywheel or they need to be broken apart???
Old 05-23-2003, 08:36 AM   #162
Broken apart
RandyT is offline   Reply With Quote
Old 05-23-2003, 07:49 PM   #163
popsracer's Avatar
Default Racing Clutch
The first time you need to install the shoes seperately, then hook the spring together. After that you can remove the hole Clutch (shoes/spring) as a unit without disassembling it.
Old 05-23-2003, 10:42 PM   #164
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Anyone going to the June 1 race at Camden? This will be my first time racing there. Do they change the track layout everytime?
DOMOisCOOL is offline   Reply With Quote
Old 05-23-2003, 10:51 PM   #165
Dan
Dan's Avatar
www.rcracing.com
Check out the message board. Mostly all bay area guys. They should answer any questions you might have. I can't make it to that race but anyways, have fun!
[SIZE=7]M11,M8,SPEKTRUM AND MORE[/SIZE][COLOR=Black] gonzo416 R/C Items: For Sale/Trade 0 10-12-2005 07:50 PM
Associated RC18T super 370 size N4S R/C Items: For Sale/Trade 17 08-05-2005 04:17 AM
Car Discussion: Which One Is The Best ? darthkir Nitro On-Road 34 01-27-2003 03:17 PM
