Old 01-12-2007, 06:42 PM   #16
Originally Posted by GrandeGixxer
Anyone know where one could get a "SnakeSkin" File for rounding these corners? I have been looking for 1 for over a year now. A buddy of mine has 1 but he has had it for years and doesnt know where to get 1 now.
I dont know wher you are located but I bought one at Revelation Raceway for $8.00, last year.
jake alton is offline   Reply With Quote
Old 01-12-2007, 07:14 PM   #17
Metal files work well due to heat transfer vs. sandpaper. With a metal file, the heat buildup is transfered to the file vs. staying in the tire. Similar concept to soldering where you use a pair of pliers to distribute heat from continuing down the entire wire.
BryanLynn is offline   Reply With Quote
Old 01-13-2007, 06:22 PM   #18
Trader Rating: 74 (100%+)
You can find this carbide file in the ceramic tile section at Lowes or Home Depot. Been using one for 5 years, it still looks new !
http://www.lowes.com
Type in search box: ceramic tile file
Nitro-mech is offline   Reply With Quote
Old 01-13-2007, 11:44 PM   #19
RC Migs's Avatar
Unhappy
http://www.lowes.com/lowes/lkn?actio...7616-1255-2716
Not sure if it's just my computer but that link you posted doesn't want to work for me for some reason. Do you happen to have an item or stock # for it...? Maybe I can look it up that way.
Thanks,
Mike
RC Migs is offline   Reply With Quote
Old 01-13-2007, 11:52 PM   #20
nitrothugg's Avatar
Tile Solutions
Ceramic/Marble File
Item #: 17616 Model: 2716
nitrothugg is offline   Reply With Quote
Old 01-14-2007, 02:01 AM   #21
itchy b's Avatar
Originally Posted by Snowy
The Border On-line shop in Holland sell the "SnakeSkin" file. Not cheap but well worth it!
Click here
And to think that in Brisy you told me that they don't make them any more
I have used one of these "snakeskin" files and must say that they are the best out there for the tyre truing job.
Quick and easy to shape and a nice finish.
Thanks for the info Snowy, even if it's 5 months late
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 01-14-2007, 01:27 PM   #22
fraz's Avatar
Send a message via AIM to fraz
Originally Posted by straightaway
Rounding the edge of foam tire after cutting? is this necessary and what will this do vs square edge? Thanks.
I have read the article posted, and all the replies and it doesn't look like anybody answered your question.
Josh mentioned in his article that it helps the tire break in quicker to the surface and that is because there is less tire contacting the ground. To me, the function of cutting pre-camber does more to break in the tire. Aside from that, there are two main things that putting a radius on the tires gets you. First is a smaller sidewall so you get less lateral grip. If you are on a track with terrible traction, you can put a smaller radius on your tires and this can help some. The second item is mainly to prevent chunking. If you go out with a 90 degree edge on your tires, the more prone you are to catching an egde and chunking your tire.
As for file types. The snake skin ones rock for doing nitro front tires. They can be a little too agressive for some rear compounds. I have a cheapo $1 file from Home Depot that works well. I also use an ancient rasp/file with less bite for softer compound tires when I race electric.
fraz is offline   Reply With Quote
Old 01-14-2007, 03:28 PM   #23
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
I knew you would say that!
They were out of stock for a while Mr Itchy. So get in quick before they all go again.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 01-24-2007, 07:09 PM   #24
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
For anyone who wanted the rasp from mcmaster, it is on page 2543 in the new catalog.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Rounding tire corners after truing thunderbt3 Nitro On-Road 8 06-06-2007 06:17 PM
rounding edges of tire Sal Amato Electric On-Road 5 01-24-2006 06:04 PM
RC Electronics Cutting Edge-NOT imjonah Electric On-Road 31 01-02-2005 03:06 PM
Foam tire edge clean-up tool rcfoolz R/C Items: For Sale/Trade 2 02-11-2004 09:52 AM
Foam tire edge sander Randy Caster R/C Items: Wanted to Buy 14 02-09-2004 09:37 AM
