Old 03-05-2003, 10:40 PM   #1
Send a message via AIM to synapse79
Default 235mm 2wd setup help
Can anybody help me with the initial setup for a 2wd serpent impact. I built one out of spare parts that i plan on racing in the cincinnati and toledo area.
What im really curious about, is whether i should set the car up with a floating rear end. Should i run swaybars from or rear?
General idea on what oil and springs to start with would be cool too.
Thanks to anybody that can help
jason
posted on a few other sites, thought i would try here...
synapse79 is offline   Reply With Quote
Old 03-06-2003, 06:16 AM   #2
Here is a link for a standard set-up for the 835. You didn't say what diff you have, but I would recommend the FPS diff (if you don't already have it). I found the ball diff very difficult to set-up correctly.
http://www.mytsn.com/setups/setup.asp?sid=1452
veesix is offline   Reply With Quote
Old 03-06-2003, 07:16 AM   #3
Turbo9000's Avatar
Go to www.myrcworld.net and search for clubs that use the Impact.
Turbo9000 is offline   Reply With Quote
Old 03-06-2003, 02:59 PM   #4
Send a message via ICQ to David
go here....http://www.mytsn.com/
Its Got EVERYTHING thats Serpent including factory and personal setups
David is offline   Reply With Quote
Old 03-06-2003, 03:37 PM   #5
Dave
and do what?
veesix already showed me serpents standard setup on that site...
problem is it doesnt say what kind of body the setup is for or whether or not it is for a floating rear end.
Ive been looking into getting an FPS diff. I may try it for a while with a ball diff if I cant find one used or cheap.
Thanks for the help though
Old 03-06-2003, 05:16 PM   #6
theRED5's Avatar
R/C Tech Charter Subscriber
Most run TC bodies in 2wd 235...I would think the set up is for them.
Make sure you have plenty of rear toe in....no rear bar, just the front one.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 03-06-2003, 05:20 PM   #7
thanks for the help
I was pretty sure i needed a touring body, and i guess there is no point setting it up with a floating rear end then...
Old 03-06-2003, 06:03 PM   #8
Originally posted by synapse79
Dave
and do what?
look under the setups section and you can get any number of setups for both 2wd and 4wd
as regards to bodies most 2wd cars use the GTP bodies those are IFMAR rules
w/235mm tc body ,, waytoofast R/C Items: Wanted to Buy 1 08-08-2006 08:42 PM
SERPENT 235MM OUTLAW COMPLETE SETUP CATDUDE R/C Items: For Sale/Trade 0 07-05-2005 08:03 AM
235mm car setup trashcar R/C Items: Wanted to Buy 4 05-07-2004 10:12 AM
1/10 235mm Onroad icon Nitro On-Road 19 10-27-2003 09:55 AM
235mm or 1/8 TambokGT Nitro On-Road 12 10-21-2003 03:03 AM
