Old 01-04-2007, 09:01 PM   #1
XNXIXTXRXOX's Avatar
Default Ground Effects
Has anyone here used "Ground Effects"? its a liquid you apply to your tires and let them soak it up... it gives you a lot more traction... It work really well for me. Has anyone else used it?
XNXIXTXRXOX is offline   Reply With Quote
Old 01-04-2007, 11:10 PM   #2
Trader Rating: 14 (100%+)
Traction compound is mainly for electric racers that run shorter races than us nitro guys. Theyre running 5-8min heats and mains where we run 5-10min heats and 1 Hr mains. I've seen some nitro sedan guys run it but I don't see where the advantage is. You run your 5 minute heats and have awesome traction but when it comes to an 1/2 hr to 1 hr main, you have an advantage for the first 5-8min but when the compound burns off, you're driving a completely different setup. Not flaming putting compound on tires, but I rather find a good setup and tweaking it during the qualifiers and hopefully have a dialed car for the main.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 01-04-2007, 11:17 PM   #3
litespeed-dom's Avatar
I agree with thunder.
If you are suffering lack of grip, there are many other ways to get more traction out of your car. Also, gas tracks usually already applied some kind of traction additive to begin with... VHT, sugar water/grape soda...
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 01-05-2007, 04:45 AM   #4
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I agree with Thunder too, but the only time I will use it is at club racing when the main is only up to 15 min. Then I only use NIFTECK, it seems to last longer then the other stuff thats out there.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 01-05-2007, 10:02 AM   #5
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
I agree with thunder its all about setup.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-05-2007, 10:08 AM   #6
Yea i guess, but i have had a problem with my car ever since i added more power to it. when the traction isnt good, the rear end shoots out to the left making the car go right. when i apply the tire compound, its fixed. Now is the another solution to my problem like a setup issue or differential problem?
Old 01-05-2007, 10:08 AM   #7
This occurs when i go full throttle
Old 01-05-2007, 11:59 AM   #8
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Sounds like a shaft torque thing to me, this is the reason the flash lite guys only use belts in mod. In stead of piling money into your current chassis maybe you outta give a belt car a whirl...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 01-05-2007, 12:51 PM   #9
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
In a bind ive added some traction sauce to the front or rear or both dependant on the tracks current grip. This is more of a quick fix for grip when the track is giving me trouble. Normally this is when I also notice other drivers having this problem.
Otherwise I try to play with the suspension some in between heats to rectify. I use a few as well I normally like to presoak my tires in tire tweek , so the day of there really isnt anything needed.
Artificial-I is offline   Reply With Quote
The effects of using different glow plugs! motomanpat Electric Off-Road 25 10-30-2008 03:43 PM
HEN lean and LEN rich...effects? keavze Nitro On-Road 1 11-09-2007 03:58 AM
The effects of having bad exhaust gaskets motomanpat Nitro Off-Road 15 11-05-2007 03:29 PM
Paragon Ground Effects Tire Sauce Woes Mr. McGoo Electric On-Road 7 08-17-2005 10:52 PM
Headlamps & light effects? silacomalley Painting, Designs, Graphics and Photography 3 07-31-2005 05:35 PM
