Old 01-01-2007, 05:23 PM   #1
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
Default help keeping fuel line in tuned pipe.
I was out breaking in my new engine today on my new ntc3 and the pipe has a hole for you to slide the fuel line in. i did that and it came out when i was driving the car. I burnt my fingers trying to put it back in. Is there any way to hold this in there with something to keep it in? thanks.
NitroMaxx3.3 is offline   Reply With Quote
Old 01-01-2007, 06:14 PM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
You can buy a fuel pressure outlet and just screw or glue that sucker on...maybe even jb weld it if need be.
Or just get a real pipe.
Artificial-I is offline   Reply With Quote
Old 01-01-2007, 06:18 PM   #3
i thought i got one of the best pipes for the ntc3 it was 45 bux and dual chamber. idk though
Old 01-01-2007, 06:21 PM   #4
Trader Rating: 15 (100%+)
I have only seen pipes that have a nipple that you slip the fuel line over.
THE DOCTOR is offline   Reply With Quote
Old 01-01-2007, 06:26 PM   #5
Moderator
45 bux....what was it?
Old 01-01-2007, 06:41 PM   #6
http://www2.towerhobbies.com/cgi-bin...?&I=LXCKN0&P=7
heres the link. i got pics loading now.
Old 01-01-2007, 06:46 PM   #7
heres a picture of the pipe
Old 01-01-2007, 08:47 PM   #8
DogboneS's Avatar
Trader Rating: 20 (100%+)
If you have access to a selection of fuel lines you may be able to find one that has a larger outer diameter. I believe that the dubro fuel line comes in a thicker walled size that has a larger o.d. You may also be able use a longer length of hose and enter the pipe at more of an angle so it catchs better. I've seen this type of pipe on an MGT monster truck.
DogboneS is offline   Reply With Quote
Old 01-01-2007, 10:24 PM   #9
Send a message via AIM to T1bobo
You did really this is the only pipe that works with the NTC3 because of the way the engine sits in the car your best bet would be to buy a nipple for it and jb weld it on!
T1bobo is offline   Reply With Quote
Old 01-02-2007, 05:58 AM   #10
mugendude's Avatar
what you do is stick the fuel line in tjhe pipe a couple mm it will have extra line in the pipe so it will stay in better or at least it will stay in for a longer time period hopes this helps
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 01-02-2007, 12:22 PM   #11
Big Jeff BBQ's Avatar
BUY A DIFFRENT CAR THAT USES A REGULAR PIPE !
OR SCREW IN A NIPPLE AND SEAL IT !
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 01-02-2007, 08:13 PM   #12
NitroMaxx there is nothing wrong with the car or the pipe, the hole is just way too big for any threaded nipple to fit it. you just need to buy a larger diameter fuel line, cut a small angle on the end of the line and work it into the hole using a small screwdriver. I have three NTC3s and used them to dominate two smaller club tracks in my area for 3 years, I never lost a quallifier or a main at one place and in the 3 years was only out quallified once and lost 3 mains at the other track. This car will run with anything out there on smaller club level tracks.
Good luck & good racing
And Mr. Epperson you made great food next to me at the last Winternats race, but your car repair advice stinks. See you at the Winternats shortly.
427 COBRA is offline   Reply With Quote
Old 01-03-2007, 05:20 AM   #13
I have never ran a race car with a piece of fuel line just stuck in a hole.
The motors i have ran will blow any line out of a hole thus,changing the tuning on the motor,i have allways just screwed a small nipple into the pipe
and attach the fuel line to the nipple!
I dont see the problem with the repair advice?
The stab at the ntc3(ac) was just in fun,i try to add a little here and there
sorry if i steped out of line.
Cooking is my real gig, the race is the FUN.
See you soon
Grill--Race car--Cooler
Later
Jeff Epperson
Blowin' Smoke BBQ
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
GRP Tuned .21 Engine w/2053 Tuned Pipe (Turbo Plug) Poor Boy Racing R/C Items: For Sale/Trade 12 08-03-2011 09:46 AM
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 07:52 PM
JP Racing First Line .12 on road Stock and Tuned romuald31 Onroad Nitro Engine Zone 153 04-17-2010 05:35 PM
JP Racing First Line .21 on road Stock and Tuned romuald31 Onroad Nitro Engine Zone 6 04-12-2008 07:13 PM
NEW HPI NITRO FUEL TANK W/ PRIMER (75cc) AND TUNED PIPE (COMPOSITE NYLON) bst R/C Items: For Sale/Trade 0 07-26-2004 02:46 PM
