Old 12-28-2006, 06:31 PM   #1
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
Default Sealing the engine tomorrow.
i am recieving my new picco .12 roar engine in the mail tommorow and will be sealing it and blue locktiting the screws. what sealer is the best to use? while im at it should i blue locktite all the metal to metal screws? thanks.
NitroMaxx3.3 is offline   Reply With Quote
Old 12-28-2006, 07:19 PM   #2
I've never used loctite on any screws on my engines...
Luke W is offline   Reply With Quote
Old 12-28-2006, 07:36 PM   #3
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I have never sealed or used loctite on my nitro engines. I am not against sealing the engine, but I wouldn't do it unless I suspect there is a problem.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-28-2006, 08:01 PM   #4
the engine i am getting though has had some air leaks right out of the box. i am debating on whether to seal it before i run. hee is the engine.
http://www.ofna.com/eng-picco-roar.html
Old 12-29-2006, 04:33 PM   #5
CurveTracer's Avatar
Default Ofna Picco .12 engine
I have had a couple of these engines. The first one I purchased in May of 2005. It ran fast but sensitive to needle settings. I discovered a leak in my fuel tank 3/4 full line in the seam. After the tank repair the engine was much better from idle quailty to full power. It failed with a broken connecting rod, (my fault, the flywheel nut looseded up (8/2005)).
I purchased another one in Sept. of 2006. This engine was like night and day difference from my original. It is much easier to tune and the carb appears to have been updated internally. The LSN needle settings are very different.
CurveTracer is offline   Reply With Quote
Old 12-29-2006, 04:37 PM   #6
Default Air leaks
I did seal the carb and its tightening bolt on my old engine. I did this before I discovered my leaky fuel tank. As for my current engine, I have not found any air leaks, so I have not bothered with sealing it.
Old 12-29-2006, 07:09 PM   #7
bvoltz's Avatar
Trader Rating: 44 (100%+)
How do you check the engines for air leaks? I understand what you are doing, I'm asking for what tools do you have or purchase? What do you use to block the carb area and exhaust area?
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 12-29-2006, 07:49 PM   #8
lil-bump's Avatar
Trader Rating: 83 (100%+)
Your finger. If the engine runs more than one second after you completely cover the intake with your finger then you have an air leak.
How are those Picco roar legal engines. I have one that I have not ran yet but I plan on using it next season. I got mine with out the exhaust sytem. Other than the smaller than usual header size it seems pretty decent when I broke it in.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-29-2006, 08:32 PM   #9
actually i just recieved mine in the mail today. all looks good going to fire it up and break it in tommorow. it looks like a well built engine. got the sealer incase of any leaks.
Old 12-29-2006, 09:21 PM   #10
Sounds like a plan!!!
My breakin was pretty easy once I got a few tanks of fuel through the engine.
The engine is more of a low torque power plant. I like the way it runs geared up. With the proper gearing, you can keep up with most cars on the track.
Sealing the engine catkchun Malaysian R/C Racers 5 07-17-2008 05:25 PM
Engine sealing. rdsoxfn Nitro Off-Road 27 04-04-2008 08:46 PM
Sealing your engine? razor_clawzz Malaysian R/C Racers 2 01-27-2008 06:51 PM
Engine Sealing SPZA Electric Off-Road 2 03-24-2006 08:57 PM
Sealing an Engine rcfoolz Nitro On-Road 10 01-28-2005 12:17 PM
