 Tire choice for parkinglot racing!(revisted) >
Old 03-01-2003, 11:27 PM
Fiream's Avatar
Post Tire choice for parkinglot racing!(revisted)
Hey guys,
Since the my first post on this topic, got over 200 posts, i'd figure i'd "revist" it and give you some photo help to help improve my setup.
I have posted a picture showing normal track conditions. Any question you have feel free to ask. Also my one questio should I run higher ride height i'm at 5mm right now?
Attached Thumbnails  Tire choice for parkinglot racing!(revisted)-tracksetupdrunk.jpg
Fiream is offline
Old 03-02-2003, 12:47 AM
i'd definetely run higher, do u have mighty big scratches in the bottom of the chassis.
V-One S is offline
Old 03-02-2003, 11:40 AM
Fiream's Avatar
Yes I have a few good scratches on my chassis...
Fiream is offline
Old 03-02-2003, 12:18 PM
I would recommend running the ride height up a little more, (6mm)if your car has limiters I would suggest to use them. That looks like a nasty couple of bumps. Is that a handicapped ramp in the way of your straight away? How big is the overall layout of the track anyway.
mobil1rac is offline
Old 03-02-2003, 01:38 PM
Fiream's Avatar
Yeah its pretty bad parkinglot, the owner of the hobby store is looking for a new place in the area ASAP. To answer your question, No the handicap ramp is not part of the track....
Layout: 70 ft by 30ft or 24 meters by 10 meters.
Now that one angle of the parkinglot, if you see turn 2 that a very steep down hill left hander. If we make the track so we get a long back stright, there a huge ass bump in the middle, most of the faster guy running Yokomo's, TC3, Supernitros, ect... get airborn over that thing, like almost a foot in the air. It's pretty wild...
Rob
Fiream is offline
Old 03-02-2003, 10:36 PM
Fiream's Avatar
ttt
Fiream is offline
Old 03-02-2003, 11:12 PM
popsracer's Avatar
Default Tire choice for parkinglot racing!(revisted)
Fiream;
OH NO NOT AGAIN!!!!
That's one rough looking track. I've raced on Off-Road tracks with less bumps... just kidding, well almost.
From the looks of that surface (Well worn Asphalt?), I recommend Yokomo 138G's. They usually work best on a rougher surface as you have there.
If the chassis is bottoming out on the bumps, then raise the RH by 1mm. You could also try a few steps heavier shock oil too. The Traction should be great except for the jumps (bumps).
popsracer is offline
Old 03-03-2003, 01:58 AM
If there is major scratching, like grooves through the chassis, i'd go up by at least 2mm, and up to about a maximum of 4 mm, maybe go 1 step harder springs on the front, and back, and a slight heavier oil in the shocks, 1 step up front and back again.
It will respond a little bit quicker to your turning commands as well, and could slide around a bit with a higher height.
All though hopefully stiffer suspension will prevent it form happeneing to much by stopping too much weight transfer.
V-One S is offline
