Like Tree6Likes
Old 05-18-2007, 10:46 AM   #1006
mtveten's Avatar
Trader Rating: 27 (100%+)
Originally Posted by stefan
The more I read from and about Hudy, the less I like him.
"The engine mounts on some of the Novarossi engines may not fit perfectly on the NT1 engine mounts"
No Idiot, your f.cking engine mounts do not fit the Nova engines, simple as that.
But how could a world reknown top engineer with the most brilliant ideas ever, make a simple mistake like that.
So, you XRay deciples rather Dremel away on your engines....
To be fair the NT1's engine mounts fit current and 2 generations previous Nova blocks at its release. I haven't seen a 353 but I know the plus, LS & LL are fit fine.
Mark
mtveten is offline   Reply With Quote
Old 05-18-2007, 11:02 AM   #1007
rmdhawaii's Avatar
Originally Posted by Sow&Steady
Oh man, I feel for you. To me, not having a permanent track for on-road is just a sin.
Hey! Its an opportunity, form a club, do one up, call it KB-Raceway!
We just need the permanent track. We have about 30-40 guys show up for extremely well-organized races twice a month. Our championship this year had 60 entries. On-road Nitro racing is alive and well here in Hawaii.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-18-2007, 11:13 AM   #1008
GK
Suspended
You also have idiots who for some reason can't accept that another manufacturer started producing 1/10 nitro car. And the fact that it actually performs really well is hard to swallow for some...
GK is offline   Reply With Quote
Old 05-18-2007, 11:25 AM   #1009
kitracer's Avatar
Originally Posted by SlamMan
I'm using the white shoe that came with the kit, and I set the gap with my caliper.
Try this tool to mea clutch gap.
http://rc-mushroom.com/product_info....ducts_id=11951
very consistence reading so when you make any changes, you have a standard value all time.
I suggest stay with 0.7 clutch gap. I used serpent hard long spring http://www.serpent.com/product/909520
the spring tension depends on track condition. I start with 1.5mm
I did not use any shim between the engine and the cone.
hope this help
kitracer is offline   Reply With Quote
Old 05-18-2007, 04:00 PM   #1010
ChrisP's Avatar
Mark
I agree....unfortunately he was unable to forecast that Novarossi would make a change to their mount...
ChrisP is offline   Reply With Quote
Old 05-18-2007, 04:07 PM   #1011
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Mark
mark>pwned>stefan
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-18-2007, 04:08 PM   #1012
rmdhawaii's Avatar
I need some help with the centax clutch. This is my first gas car so... I'm running the OS TZ 12
I finally got to run the car in an empty parking lot today. I ended up loosening the centax clutch all the way out to get it to engage? I didn't try tightening it back up after which so I'm not sure if it's relatively light or stiff. I certainly can't go any lighter though.
I'm under the impression this isn't normal. How much did you guys have to adjust the clutch from the original settings? Should I change something? would changing the clutch gap help?
One thing that struck me as odd was that I didn't have to use a single shim to achieve the proper flywheel gap, clutch gap, and clutch bell end play as according to the instruction manual. The motor was dead on to the measurments from the book without any shimming.
Try this: Take the engine out of the car and point the engine with the gears pointing straight up at the ceiling and spin the clutch bell. Does it spin for about 5 seconds or is it dragging on the clutch shoe? Also try the same with the gears pointing straight to the floor.
Also, how much gap is there between the flywheel and the crankcase? If the collect is significantly protruding out the back of the flywheel on the crankcase side, it may have taken up all the gap that is usually shimmed.
Old 05-18-2007, 05:32 PM   #1013
Default Thanks
hope this help
Thanks for the link just what I am after
flyspray is offline   Reply With Quote
Old 05-18-2007, 06:02 PM   #1014
Sow&Steady's Avatar
RMD, I uploaded a DVD version to Veoh.com but it didn't turn out so good
http://www.veoh.com/videos/v507784APKJwqsR
Only the slow moving or relatively stationary scenes looks good.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-18-2007, 06:13 PM   #1015
rmdhawaii's Avatar
DVD quality sounds nice. I will check it out when I get home.
FYI for everyone else: The Flash Player version is a lower quality. You get the high quality version when you download the file.
Old 05-18-2007, 06:18 PM   #1016
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default host
sow, try using www.revver.com nice quality on that site.. your movie will be downloadable once it is uploaded.. and its in quicktime format.. so easy viewing for ipod video users out there.
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 05-19-2007, 02:32 AM   #1017
rmdhawaii's Avatar
You're right! Does the version you created on your computer look better than the one that gets downloaded or does it look the same? Is your original also 160MB? How are you encoding it? What is the resolution?
Old 05-19-2007, 03:05 AM   #1018
Sow&Steady's Avatar
Ah ok, let me have a look and try that one too ... thanks.
Old 05-19-2007, 03:09 AM   #1019
Sow&Steady's Avatar
The one which I uploaded in Veoh.com is DVD quality and yes, for 3 mins of video its 165 MBytes. PAL DVD is encoded into MPEG right? Not sure on resolution ... 640x480 I think because I can watch it on my widescreen LVD TV and the quality is as good as any commercial DVD I watch.
I have not downloaded it from Veoh but let me try and see what they did compared to the original.
Old 05-19-2007, 03:11 AM   #1020
ianhobbies's Avatar
Default revver
btw the site has a 100mb limit
