Like Tree6Likes
Old 11-24-2013, 05:22 PM   #7081
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
So this is the second weekend out with the car and I have an issue with corner speed. It seems like on off power going into the turn it likes have understeer along with corner exit. I was wondering what most people would do for that.
Also I have had an issue with the rear shocks and the bottom shock cap staying on so I will be running and then it finds its way loose so the rear end has oil all over everything. I even use red loctite on it and it still came off. Any one else have this issue or know of a good fix for it?
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 11-25-2013, 08:59 AM   #7082
snuvet75's Avatar
Trader Rating: 16 (94%+)
The shock cap, is it aluminum or plastic? I suppose u know loctite will not do anything w plastic so i guess it's aluminum? Then something's gotta be terribly wrong. New shock body and cap should follow.
Exit understeering can be fixed w higher front and/or rear diff oil depending on how your car behaves on the rear of the track.
Other than diff oil, different springs,higher front droop, lower shore front tires, thinner front sway bar or messing w roll center can be tried.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 11-27-2013, 02:59 PM   #7083
Post subject: Re: Progressive SpringsPosted: Thu Nov 29, 2012 10:02:52
team driver
They do make the car more aggressive and have a more direct feel in the middle of the corner. They are suitable for high grip tracks where the rear is already planted and the car could use some more turn-in. The kit linear springs are easy to drive. These will increase overall grip and steering.
I read this about the silver progressive springs for 2012 nt1.
Does this describe them?
I've used the rears but never the fronts, I like the rears and switch between them and pinks. If traction gets really high next week in Kissimmee I'm gonna try them all around
JOE SI is offline   Reply With Quote
Old 11-27-2013, 02:59 PM   #7084
team driver
Old 11-28-2013, 07:47 AM   #7085
GREGORY!'s Avatar
Originally Posted by GREGORY! View Post
What is the internal diameter of the new low profile shocks?12mm?
Anyone??
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 11-28-2013, 01:54 PM   #7086
Anyone??
I am going to rebuild my car tomorrow and will make sure to measure it for you. I believe that is correct though, but will verify.
Jay Williams
Xray RX8 2014
Old 11-29-2013, 01:33 PM   #7087
GREGORY!'s Avatar
Just check the rest of shock pistons that comes with the kit!
Old 11-30-2013, 06:09 PM   #7088
MrHistory's Avatar
Anyone have a nt1 2013 Ed setup sheet for Kissimmee? Especially would like to know the gearing. Full sheet would be great though. Thanks.
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 12-01-2013, 04:49 PM   #7089
The pistons are 11mm and the outside of the shock body is 13mm. So by that I am assuming the inside of the shock is 12mm. Hope that helps!
Jay Williams
Xray RX8 2014
Old 12-01-2013, 09:28 PM   #7090
GREGORY!'s Avatar
If pistons are 11mm the inside diameter is 11mm too.
Thank you very much!
Old 12-07-2013, 09:03 AM   #7091
Hello guys
please, someone can say me the dimensions of xray shocks springs (code #338, for example light purple, or violet)?
I need to know the lenght of rear and front springs and the internal diameter.
Thanks in advance !
maRRRco is offline   Reply With Quote
Old 12-11-2013, 07:53 AM   #7092
afm
afm's Avatar
Default 7th INTERNATIONAL PACIFIC CUP LIMA - PERU March 7 9, 2014
Hi guys,
Want to share with you the latest aerial video promoting our track and the
7th edition of the Pacific Cup in Lima Peru
http://www.youtube.com/watch?v=Q2zuJy5TnHA
also to let you know that registrations are open and flowing at:
http://www.apercar.com/copa_del_pacifico.html
just make click on FORMULARIO DE REGISTRO and register
and if you want to check who is registered make click on INSCRITOS
Is it March????.......come guys you are most welcome to a great event with our special latin treat.
AFM
afm is offline   Reply With Quote
Old 01-14-2014, 01:17 AM   #7093
snuvet75's Avatar
My NT1 has very inconsistent gear shifting. Sometimes it doesn't even shift or it shift way too early no matter how tight the 2nd gear shoe is. I checked the one way bearing, clutch and got a new shoe for the 2 speed and still same problem exists. I just re built the car and in the process of re building the engine(O.S. XZ). I just couldn't finish it today because the crankshaft bearing is jacked a bit so I have to get a new one. What else should I check??
Old 01-14-2014, 06:14 AM   #7094
HHH
HHH's Avatar
I know you already mentioned checking the clutch but when I have had similar issues it was the clutch nut sliding to less pre load because my engine was powerful and I did not thread lock the clutch nut.
If it shifts way too early make sure you have at least 0.20-0.30mm preload on the clutch spring collar relative to the clutch nut and that you use thread lock to keep it in place. When the pre-load is zero or less or close you will get early and inconsistent 2nd speed engagement no matter how you tighten the 2nd speed shoes.
Let he know if not clear. Worth a check and try.
HHH is offline   Reply With Quote
Old 01-14-2014, 08:12 AM   #7095
Are you oiling the second gear bearing? If you are doing that, stop doing it lol. What is happening is as it spins it gets oil in there creating really inconsistent shifting or not shifting at all. Also clean out the inside of the 2nd speed gear with rubbing a little rubbing alcohol on the 2nd gear ring to remove any access dirt that is on it first of all. I do the same to 2nd gear shoes as well. Also make sure your screws in the shoes are tightened the same amount. If they aren't tightened the same amount you will definitely get inconsistent shifts.
Jay Williams
Xray RX8 2014
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
horchata
